Head/Plug question?
Old Feb 12, 2003 | 02:46 PM
todd abbott's Avatar
Head/Plug question?
With all the talk about heads blowing plugs as of late, I would like to know if anyone has put high temp thread locker ( the removable type), on the plugs and if so how has it worked out, does anyone in the know see any problems with this and if not why aren't we all doing this, it seems like a simple solution to an on going problem. Todd
Old Feb 12, 2003 | 03:40 PM
wkuper11's Avatar
there was just a post on this, try a search. i think someone had called locktite tech line and asked. they said it should work, but the high temp stuff would liquify at 450 degrees. some said you wouldn't be able to get the plugs out after you did it. do the search though, some stuff should come up.
