How Do I get my Light switch out????
Old Feb 11, 2003 | 09:04 PM
69stangscj's Avatar
Registered User
Question How Do I get my Light switch out????
I was going to try the Technical Article on how to make our fog lights work in the auto lamp position but I'm not sure how to pull the switch out. I stuck a little screwdriver under the notch on the bottom side and pried up and the switch moved but I’m afraid to pry any harder. Any suggestions or what am I doing wrong?
Old Feb 11, 2003 | 09:08 PM
Probleminfected's Avatar
just pry along the seem, you'll get it out.
Old Feb 11, 2003 | 09:11 PM
69stangscj's Avatar
Registered User
All around the switch or just in the notch area on the bottom?
Old Feb 11, 2003 | 09:21 PM
pop it out first with the notch, then pry along the edges
Old Feb 11, 2003 | 09:24 PM
69stangscj's Avatar
Registered User
I'll try this.... thanks.
Old Feb 11, 2003 | 09:38 PM
mecca's Avatar
Screw driver to pry the clips to make em pop, then pull... I did this... was easy!
-Mike
Old Feb 11, 2003 | 09:51 PM
soap's Avatar
If you want to go all out and not scratch any edges of the dash (like me). Remove the lower dash piece that is held in by a few bolts/screws. When it is off you can access the tabs that hold the switch assembly in place. Push up on the bottom tab to loosen it then one on the side......it should pop right out
--Joe
Old Feb 12, 2003 | 07:28 AM
69stangscj's Avatar
Registered User
Thanks for all the replys guys, this should help!
