Fix For Oil in Throttle Body
So the consensus is still to block off the port into the upper plenum? What should I use since I didn't order the Swanson kit with the dime-sized plate? Ball-bearing or is there something else similar I could find at a hardware store?
LOL hslightnin. Yeah, I can see that. On the street, you have to be dilagent about emptying the sump tank. Those reversed smog pumps do not like oil. If you run too much vacuum, you have also suck the crank seals inside out .
I installed the DS kit yesterady- I'll clean the intake boot today (so is planned) and let you all know what happens.
p.s. - I am at the point that I'd pay someone $50 for a practical solution for this... that is what America is all about- supply and demand
john
john
john
john
Dan
