Question for Sal or anyone running NX system
Old Feb 10, 2003 | 11:40 AM
svt360's Avatar
Question Question for Sal or anyone running NX system
I have 1 quick question and that is how many switches are reqiured to operate the system??I ordered the full blown gen 2 setup from Sal,Id like to start working on the switches I was thinking of putting all of them in the garage door thing that is mounted on the roof.Will they all fit there????
Old Feb 10, 2003 | 12:01 PM
red gen 1 94's Avatar
There is one for main Nitrous power, one for purge and one for the bottle heater. Total is three...... I had ideas of putting mine up there but was too lazy and too excited to spray my truck soon.....Good luck.......Take many pictures! Keith
Old Feb 10, 2003 | 12:03 PM
tommylightning's Avatar
I had mine up there. I did not like it as it was harder to get to it after my burnout. I installed the power and bottle heater switches in the lower center area. I also installed the purge in the panel under the light switch.
Old Feb 10, 2003 | 12:12 PM
svt360's Avatar
thanks for the replies guys,im doing it I have 2 more months before the truck goes on the road,will 15amp switches be good enough??
Old Feb 10, 2003 | 01:04 PM
beefcake's Avatar
sal mounted my activation switch and purge here, perfect place for it, he also said this piece is pretty cheap to replace if you ever need to
the bottle heater was mounted here
i had 1 more switch in the cab on the other side for the elec fan and water pump, they were wired to the same switch
Old Feb 10, 2003 | 02:05 PM
svt360's Avatar
Thanks good info Terry,how big of a shot do you run??I believe you have a stock lower end also correct??
Old Feb 10, 2003 | 02:15 PM
beefcake's Avatar
i was running a 50 shot,
sold the system though
Old Feb 10, 2003 | 03:23 PM
D_Coburn's Avatar
You could also have a switch for a remote bottle opener....
Old Feb 10, 2003 | 03:38 PM
beefcake's Avatar
problem with mounting something hidden is that it makes it much easier for you to miss also!
Old Feb 10, 2003 | 04:13 PM
RTKILLA's Avatar
I didn't like the switches all over the dash, so I just have a couple LED's that let me know when its activated.
Old Feb 10, 2003 | 04:25 PM
cyntaxx's Avatar
how bout a "Go Baby Go" switch like Eleanor's? I've seen trucks with the main switch on the signal stalk too...however the wiring wasn't hid very well (hard to hide of course)
