Street Scenes Grill Questions
Ok, since it appears you L owners have installed a lot of these grills, I thought I'd ask a couple questions before I order one for my truck. I've read a number of old threads where L owners have described a love/hate relationship with this grill (love the look, hate the install). I'm soliciting your comments, pro or con. What's the best look, satin or chrome? Also, if you'd recommend it for my truck, share some install suggestions for getting it into the truck with the least headaches.
Fire away........
Fire away........
Chrome on silver truck
They haven't changed anything recently, so search for install directions and you're all set.
I love mine and I think it looks great (especially with the JDM heat exchanger behind the lower), but yes the install and fit are a pain.
Coldie
Coldie
i HATE the chrome grilles. IMO the satin looks much better. the chrome just looks cheap. wasnt too bad of an install. 1st thing you should do, is throw away all the metal clips they give you fror the install. use wire ties instead. also, be sure to cut out your old upper grille. it looks much better.
my $.02...chris
my $.02...chris
my $.02...chris
my $.02...chris
I know I'm really overkilling this issue, but I've pulled the grill and surround before, and given the amount of work required, I don't want to have to do this more than once.
Hey Bigdeal, i live in orlando now and have the grille. If you want to comeby and look at mine or need some help let me know.
I didnt like the way it looked with the stock grille behind it so i took it off and bent the edges outward. Looks good, and am happy with it.
MA01GA02@aol.com
MA01GA02@aol.com
Originally posted by BigDeal
So let me re-cap and hopefully I've got it straight. Pitch the clips that come with the grill. Cut out the center of the stock grill leaving only the outer band or ring (that snaps back into the grill surround). Use zip ties to mount the new grill insert to the old surgically modified grill shell. Does the Street Scenes grill fit fairly well into the old modified grill shell or do I have to do some coaxing (i.e. bending)? Do I just drill holes all the way around the old modified grill shell to run the wire ties through? How many zip ties are enough to get it mounted securely?
Hey Fast Gator, do you have the satin or chrome grills? Couldn't tell for sure from your sig pic. Your grills look exactly how I what mine to eventually look. Did you have many problems getting them into your truck? If so, what were they?
Thats because he took that pic with a $5 camera..
He has upgraded now though and should be able to give you a proper pic.:
Originally posted by cyntaxx
tinnman: on the topic of grilles, and i know you get this a lot, what grill is that? did it come with the bolt? hold did you mount the bolt? it looks awesome!
