JDM Headers....
Originally posted by Fast Gator
Hey yysenhimer
Do you know DanSS2471?
Hey yysenhimer
[QUOTE]
problem is you are never going to get a true a/f reading from the tailpipe,
if you plan on making good power, your playing with fire[QUOTE]
I know. I would like to do a test one day to compare direct a/f and tailpipe a/f at the same dyno on the same day and see what happens. If I have to then I will remove the driver O2 sensor. The dyno I go to doesn't have the capability to do direct A/f yet.
I don't know him too well. We met a couple of months ago when Mike (mrinaldi) and I went to Atco. I can't get in touch with him other than on here. He lives somehere over by RJ's
OK, just trying to save him some trouble
whatever happen to the oldskool headers you could buy for like 250
I think you answered your own question...
Its old school, kinda like what happened to the .50 a gallon gas
Catch my drift
Catch my drift
Originally posted by cpeapea
man, i want a set of these headers bad, but does anyone else seem to think that the price is high as a giraffes ***? whatever happen to the oldskool headers you could buy for like 250
being 18 and in college leaves one a little short on $$$ tho
Beefcake , can you explain what you mean by playing with fire ? I am thinking of getting long tubes soon and would like to know everything I can before purchasing them.
Good info guys. Justin is sending me the hardware in question. Simple mistake.
Beefcake- Does the measurement from the tailpipe tend to be leaner or richer than the more accurate wideband measurement upstream. Has anyone here ever tested both at the same time. I may be wrong, but would guess that the tailpipe measurement would tend to be leaner due to the exhaust having already passed through the cats and the distance from the engine. This would cause one to have an inperfect tune, true; but, one that errs to the side of caution instead of danger. I could be wrong I guess.
What most tuners do is to remove one of the O2 sensors and put in a wideband O2 sensor hooked up to an A/F meter. They then tune to that, with only one O2 sensor in place. If you have an extra bung welded into your exhaust then they can tune with both O2's sensors going, which will be even more accurate for the whole tuning session.
