pinion angle ?
Old Feb 5, 2003 | 06:31 PM
99REDBOLT's Avatar
Smile pinion angle ?
what is the correct setting on the pinion angle for lightning stock and lowered 4 inches inthe back. mine is around 2.5 with the 6 degree bell tech shim. i think it was around 2 from the factory. what is the least or most you should have, i want it perfect before i put my traction bars on.
Old Feb 5, 2003 | 07:18 PM
ICULOKN's Avatar
Re: pinion angle ?
You have 2.5 positive? If so thats not a good thing for drag racing. You want -2.0 or so.... Most from the factory I have seen are about 1 positive. I run mine alittle lower but I dont drive mine everyday either.....
Old Feb 5, 2003 | 08:16 PM
99REDBOLT's Avatar
mine is -2.5 degrees . if it was positive it would vibrate terrible. what is the correct setting? mine was -2 degrees from the factory.
Old Feb 5, 2003 | 10:22 PM
ICULOKN's Avatar
-2 to -4 is inthe range, more negative more hook, but harder on U-joints driving around....
Old Feb 6, 2003 | 07:23 PM
SVT_KY's Avatar
Ummmm, exactly how do you measure this? TIA ...
Old Feb 6, 2003 | 10:38 PM
KINGPIN's Avatar
Kind of off topic I guess. When I installed my Hotchkis 2" lowering leafs on my 03 I noticed that the stock springs had 2 degree shims already installed. I'm positive my 01 didn't have them stock. Anybody else notice this?
Jeff
