Help with jl ram air kit
Does any one have any pics.. Well heres my problem, i unbolted and took my stock air box out, well the seal between the rubber boot abd the air box is crap now. Was i supposed to reuse this. 2. ? is there a insert you bolt up to the boot and slide into the metal casing , or doesd the plastic piece bolt up to it, and do you use the factory bolts or does some come with it.
Thanks for the help
Thanks for the help
Re: Help with jl ram air kit
Originally posted by lightning856
1. Was i supposed to reuse this. 2. is there a insert you bolt up to the boot and slide into the metal casing
2) No
The stock boot from the fender to air box goes into hibernation. You do not need it.
--Joe
