Differential Cover Gasket
Old Feb 2, 2003 | 02:01 AM
ICULOKN's Avatar
Has anyone bought one from a Auto Parts store? Or is this a dealer only item?? All are the same from 99 up right?
Old Feb 2, 2003 | 02:07 AM
mrinaldi's Avatar
I've installed many gearsets in my time, and don't ever remember seeing a gasket for the diff. Blue RTV always worked for me along with torqueing the bolts correctly.
Old Feb 2, 2003 | 08:30 AM
superfords's Avatar
there is no gasket. use black or grey rtv silicone sealer.
like this :
later,
chris
Old Feb 2, 2003 | 09:01 AM
VINNIE's Avatar
I agree with the last two statements.
Old Feb 2, 2003 | 09:39 AM
69stangscj's Avatar
Registered User
My 94 L didn't have one.....
Old Feb 2, 2003 | 11:34 AM
soap's Avatar
I used black RTV
--Joe
Old Feb 2, 2003 | 11:40 AM
ICULOKN's Avatar
What about the gear oil? Some say 75/140 some say 80/90.
Also what about the posi trac additive. I heard some say its better with and some say its better without??
Old Feb 2, 2003 | 11:46 AM
superfords's Avatar
I'm not getting into a gear oil debate, but Ford calls for the 75-140 synthetic only gear oil for these axles.
there are alot of arguements in the aftermarket both for and against synthetic. but we really don't see gear oil related failures on these trucks. BTW, that oil is expensive. I think over the counter is like $25 dollars per quart?
as for the Friction Modifier...
did you replace the clutches?
if so then you should have soaked them in friction modifier overnight. and yes, I'd add a bottle (I think they call for 2).
if you are reusing your original clutches (have already been soaking in friction modifier mixed gear oil for as long as your truck has been alive, I'd say don't add it. I didn't put any back in mine, and I rarely add it in stangs. just my .02
friction modifier's only purpose is to keep your clutches quiet (by slipping) during turns.
hope this helps.
later,
chris
Old Feb 2, 2003 | 11:49 AM
ICULOKN's Avatar
hope this helps.
later,
chris
SO i cant go buy gear oil from the store? WTF.... NO I did not replace anything, just doing some PM and checking....
Old Feb 2, 2003 | 11:54 AM
superfords's Avatar
I didn't say you CAN't go buy from the store. I just said that Ford calls for Motorcraft synthetic 75-140. You may find an acceptable replacment gear oil of the same weight. in fact many people swear by other oils such as amsoil and redline and other "aftermarket" products like that. so that's up to you. in my truck I'd use the recommended product. but of course, it's also the easiest thing for me to get.
are you doing this today?
if you come by the shop tomorrow I'll give you a few quarts of the synthetic ford oil if you want it.
IF I go back out today and the dealership is open I may be able to get a few quarts today, but i'm not sure if they are open today or not.
later,
chris
Old Feb 2, 2003 | 11:55 AM
droptail's Avatar
There's no gasket. Asked the guy who replaced a rear wheel stud to be sure and seal up the rear end good cause I didn't want any leaks. Well there's an oil puddle in the garage. I bought one of those pans with an o-ring in it and will put it in soon. They charged me something like $150 just for the lube! When I have my gears changed soon, the renouned "Hooper's Rear Ends" says they don't use synthetic. And I think I'll limit the modifier to just 1 bottle too.
Old Feb 2, 2003 | 11:58 AM
ICULOKN's Avatar
later,
chris
Chris,
I am just trying to get all my parts lined up. I wana do a full service while installing the blower and all. I will send you my cell # let me know if you can help me man!! Thanks!
Old Feb 2, 2003 | 12:01 PM
superfords's Avatar
the who???
Ford says that you need to use 75-140 synthetic in the rear axle that they designed and built. I'd listen to them first.
having said that, A LOT of aftermarket gear manufacturers say not to use synthetic gear oil. in fact some will go as far as to void any warranty that they offer if they find out that you used synthetic gear oil on their gear sets. However, we rarely see gear or bearing failures on these axles, so I'd say ford's spec is a good one.
later,
chris
Old Feb 2, 2003 | 12:35 PM
GearHead_1's Avatar
Mag-Hytec covers use an O-ring gasket that is cut into the cover. I picked up the gear oil through Mag-Hytec and the price wasn't all that bad. Seems like it was $60 bucks for 6 quarts.
