What do you guys use to punch a hole in the trans pan?
tranny pan
Save the pan, remove every other bolt, then one corner, let drain from that corner and continue loosening each allowing to drain as it lowers, be patient its not that messy. oh yeah almost forgot... put a catch pan under it first... hehe..
I gotta say, i agree with others here, these people that ruin the pan are silly. there is absolutly no reason to ruin it. If you can't get a pan off without making a huge mess have someone else do it. Even if you get a tad dirty who cares, it washes off easily.
Once the pan is off, sure drill a hole in it and put a plug in so you can drain...
Brandn
Brandn
Originally posted by Lil' Ricky
LMAO!!!!!!!
"John Dangerously"!!!!!
"My sister destroyed my tranny pan once...........once."
LMAO!!!!!!!
Alright..been thinking it over and talked to a few people about it..and read all of your posts..So I think I'm gonna try to remove it to drain it. No hole.
I'll be on here next weekend with results.
Thanks..
Dan
"My mother hung me on a hook once...once."
"Magna carta, mastercharga, you missed the bus, I missed the bus, when's the next bus? Antimerridiean, uncle merridean, all the little merridieans."
Originally posted by Dan SS2471
"You fargin' bastages! I'm gonna put you bowels in a meat grinder!!"
Thanks..
Dan
Thanks..
Dan
be sure to tell us which way you ended up doing it.. i was of the same mind as you.. "save the stock pan"
started to slowly drop it and poured tranny fluid all over the crossmember & ground.. bolted it back up & punched a hole in it.
Now that's funny!!!!!!!!!!!
Originally posted by PhillipSVT
could you drill it, when dry, put a tap into it, and just bolt in a stoper?
dont' destroy it
you never know. I just loosened all the most, then removed them from the the front. With the rear jacked up, the fluid will drain a bit. Then just hold the pan up, and removed all the bolts except for the side that 's elevated the highest, gently drop the pan, let it drain. The push it up and down the fluid will slosh around and drain. When most of it's out, take the last 3 or 4 bolts off and remove the pan. Took less than 5 minutes and i have a pan if i need it.......for lord knows what. Works good ont he shelf for putting other stock parts in you took off the truck!!!
