Long tubes & starter
Old Jan 28, 2003 | 11:14 AM
Silver-Bolt's Avatar
Question for the guys running long tubes. Are you using any heat sheilding around the starter? Those tubes seem to run very close. Have you had to add any extra heat sheilding any where?
Old Jan 28, 2003 | 11:41 AM
thepawn's Avatar
I havn't had any trouble. The only place I had trouble is I had to cut part of the passenger wheel well away, it was hitting the pipes.
Daniel
Old Jan 28, 2003 | 12:36 PM
Thanks Daniel I will keep an eye on that. I know some had trouble with tranny wiring. Which wires to watch?
Old Jan 28, 2003 | 01:27 PM
Ruslow's Avatar
I can't see why you would have trouble with the trans wiring.The exhaust runs in a tunnel[heat sheild] and all the wiring should be on the outside of that shield.On my install I ran into zero problems with fitment.Stan
Old Jan 28, 2003 | 02:02 PM
Thanks Stan. I didn't see any trans wiring problems on my install. I do remember reading a couple of posts where people burnt up a harness with the L/T's. The only other tranny concern I see is on the passenger side. The return line runs very close to the heat sheild. Right where the O2 sensor plugs in.
Old Jan 28, 2003 | 03:18 PM
dealerjim's Avatar
The 02 sensor leads on the passenger side were burned through on mine and caused the tranny to go crazy. You have to make sure to tie the 02 leads away from the headers or you'll be riding home in limp mode.
Old Jan 28, 2003 | 04:18 PM
Ruslow's Avatar
My install was alittle different from everyone else but I did notice that the O2 comes out very close to the coolerlines also.I think mine was almost between them but still fit ok.Did you get the O2 extensions to work?Stan
Old Jan 28, 2003 | 04:27 PM
captainoblivious's Avatar
No problems with the starter here.
Originally posted by dealerjim
The 02 sensor leads on the passenger side were burned through on mine ....
Mine was slightly burned.
I also cut the fender liner so the the heat shielded wire would be further.
I'd rather be safe then sorry, so moving wires away from heat IMO is very worth it to do.
Old Jan 28, 2003 | 04:59 PM
thepawn's Avatar
there are some differences in truck years too... Pete's 01 had a wire running over there that I don't have on my 2000, mine is rotued somewhere else.
Daniel
Old Jan 28, 2003 | 05:26 PM
Neal's Avatar
Cool
HI!... I wrapped my starter with some heat reflecting mesh made by DEI. It's got velcro on it and you trim to fit. I thought the same thing after installing my JDM/KOOKS long tubes and decided to protect the starter. I also removed the aluminum heat sheild that used to go around the stock cats. I also had to trim the PS inner fender well a bit.
Old Jan 28, 2003 | 08:56 PM
I did get the O2 extensions to work. I had to grind the ears off the stock sensors then it went together.
Haven't re-installed the inner fenders yet but I did re-route the starter wires to be safe.
Old Jan 28, 2003 | 09:48 PM
Fast Gator's Avatar
I just paid to have it done, so I know it was done right.
He only has praticed on maybe 300 Lightning before mine
Old Jan 28, 2003 | 09:57 PM
thepawn's Avatar
Thumbs up
The man, the myth, the legend. Great guy.
Daniel
Old Jan 28, 2003 | 10:00 PM
Fast Gator's Avatar
Daniel
Well thanks Dan, but what about Shawn
Old Jan 29, 2003 | 12:07 AM
Ahhhh he's okay, he'd be better if could beat out the Gator Chips
