boost actuator wire cut
I was going to do the boost actuator adjustment trick when i notice a wire cut from it. It the first booted wire pointing toward the fire wall on the black cylinder actuator in Chuck's picture of the actuator adjustment pic.
what is this wire? was it even a wire at all? it appears to be cut or torn or something.
hrmm... maybe i can edit Chuck's to point out the wire or would that be against the copyright? I put an arrow pointing to it. how do i post it now?
are you saying that there is a cut in it?
Start the truck up, and put your finger over the cut, you should feel it sucking, if its cut. You can drive it to the dealer, but it might stall at an idle. Just keep the rpms at around 1000
