thump while idling?
Old Jan 27, 2003 | 07:43 PM
NateTrun2's Avatar
thump while idling?
Hey guys, when i was idling today in a parking lot i felt a thump and heard a thud underneath my feet. exhasut leak or what? the rpm gauge didnt move a bit doing this. what could it be. is it serious. what do i need to do to fix it?
also... how do you remove your spare tire
thingy errm wench thingy.? anyone ever do this?
Old Jan 27, 2003 | 07:55 PM
LIGHTNINROD's Avatar
The spare tire wrench(rod?) just pops out of its snaps.
D/k about your thump.........get it up on a lift.
Dan
Old Jan 27, 2003 | 08:04 PM
NateTrun2's Avatar
dont know about the thump eaither. motor pulls strong. its right under the drivers side floor board. only does it occasionally when i idle. exhaust maybe?
About the tire: i ment the actuall wench and cable that holds the spare up there under the bed (the whole housing). i want to take it off. im having problem with the big plastic tube guide that houses the thing to lower it. once i get that thing off, wont be a problem.
Old Jan 27, 2003 | 08:08 PM
Nasty Wendy's Avatar
the thump
Maybe you need to UN-pump up the volume on your radio.
Can the clunks cause this??
Old Jan 27, 2003 | 08:18 PM
NateTrun2's Avatar
hehe.my radio wasnt on.
Old Jan 27, 2003 | 08:52 PM
whitetoast11's Avatar
check your pcv valve if our trucks have one (Just switched one out on a friends ricer and fixed his rough idle no problem, never done it on my truck though) and plugs, could just be a rough idle.
Also may want to clean the iac valve and check the fuel filter, a rough idle is not neccesarily a bad thing, but it can definately lead to bad things if unatended to.
~Toast
Old Jan 27, 2003 | 09:33 PM
NateTrun2's Avatar
i need more input. im going in to get a new fuel filter and new plugs in a week or 2. like i said. my rpm needle stays steady and it doesnt look like a rough idle.
Old Jan 27, 2003 | 09:52 PM
cpeapea's Avatar
could be maybe a loose exhaust bolt or something?
Old Sep 17, 2003 | 11:42 AM
simmy711's Avatar
I have the same thing, has this been resolved???
Old Sep 17, 2003 | 01:21 PM
clonetek's Avatar
did you just cut your AC on when you heard the noise?
Old Sep 17, 2003 | 01:26 PM
RhinoSlug's Avatar
More info please, sir! Thank you! Peace!
Old Sep 17, 2003 | 01:27 PM
simmy711's Avatar
No, I know that noise!
Old Sep 17, 2003 | 01:38 PM
GRY GHST's Avatar
NateTrun2,
I could venture a guess that it maybe related to your ABS (Anti Lock Brakes) system. Occasionally, the ABS system will go through a system check which can result in what seems like a thump or thud coming from the floorboard. The ABS Hydraulic Control Unit is located on the driver side frame rail close to the air filter. When it does a diagnositic system check the movement of the hydraulic valves can be transmitted through the frame rail and sound like a thump or thud which is normal. This is only my opinion as you said the sound was very occasional and intermittent.
Good Luck
