FRPP Lowering Kit.
Old Jan 23, 2003 | 04:05 PM
SVT F15O's Avatar
Question FRPP Lowering Kit.
Just a quick question. How much are you all paying for this kit>??? Just curious if the deal I am getting is really a "deal." Also do you like the kit>??? I will just be using the front springs out of it so...... Thanks, -Mat-
Old Jan 23, 2003 | 04:08 PM
93Cobra's Avatar
Measure before and after to makew sure that you do not have a height difference side to side. I had that problem, and it was never able to be corrected... the truck was level before I started. i definitely would not purchase these coils again... I even have an extra set sitting in my garage right now. I would go with bell tech coils up front instead if i were you.
Old Jan 23, 2003 | 04:17 PM
SVT F15O's Avatar
How much for the belltechs>??? Anyone else have this problem>??? Thanks, -Mat-
Old Jan 23, 2003 | 04:52 PM
SVT F15O's Avatar
Oh yeah......I only want around a one inch drop to level the truck with the shackles I have now. Thanks again, -Mat-
Old Jan 23, 2003 | 06:29 PM
Cali L's Avatar
Got the kit for 130 bucks (if I remember right). No problems. I was/am satisfied. It does have a harsh ride though and some serious recoil. I still think it was worth it. No leveling problems.
BD
Old Jan 23, 2003 | 06:32 PM
VINNIE's Avatar
I have the FRPP(Springs and shackles) on my truck and I installed the kit on Badazz516s truck and I had no problem with either. Both trucks are level and ride fine.
VINNIE
Old Jan 23, 2003 | 07:39 PM
SVT F15O's Avatar
Thumbs up Thanks.
Thanks guys. I am sold on it. My price for the whole kit is better then the $175 I was told for just front eibachs. I will check before and after. Is the front spring install easy or a pain. Do you need a spring compressor or will your hands do fine>??? -Mat-
Old Jan 23, 2003 | 07:45 PM
Struck in AZ's Avatar
Mat,
Yeah, your hands should do just fine...but it helps if you jump and down on the spring too before you put it in!
Try a jack under the lower control arm to take the tension off of the spring slowly...there should be pretty detailed instructions online from when Don's Bolt did his front springs if I remember correctly.
Dan
Old Jan 23, 2003 | 07:47 PM
SVT F15O's Avatar
Originally posted by Struck in AZ
Matt,
Dan
Thanks a lot man. The old ones come out easy too>??? -Mat-
Old Jan 23, 2003 | 07:54 PM
SVT_KY's Avatar
If you do just springs, you need to add the CAMBOLTS at
the same time. That way all you need to do is drop the brakeline,
unbolt the top A-arms, undo the top of the shock and the bottom,
and release the jack slowly while holding the top a-arm.
It all just drops down. I found this much easier than the
alternate of dealing with the lower control arm and pullers
and such.
Good Luck ...
Old Jan 23, 2003 | 08:02 PM
SVT F15O's Avatar
and such.
Good Luck ...
May I ask what is a "CAMBOLT" >??? -Mat-
Old Jan 23, 2003 | 09:31 PM
SVT_KY's Avatar
It's a bolt with a cam on it. Seriously. It replaces
the factory fixed shim that they align our trucks with.
I think as they go down the line they measure the
camber needed, and slap a Orange or a GREEN or
a RED shim in the upper A-Arm.
The alignment cannot be corrected without them.
I prefer the ROUSH Cambolts but NAPA makes some
cheaper ones. It's your A$$ on the line ... and your
money for new front tires if it gets loose and sloppy.
Cliff
Old Jan 23, 2003 | 09:44 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
and such.
Good Luck ...
Agreed.
You'll need anti-clunk washers also.
Bob
Old Jan 24, 2003 | 06:46 AM
Fast Gator's Avatar
I agree with that Speedin fella
Old Jan 24, 2003 | 10:13 AM
SVT F15O's Avatar
Cliff
Thanks for the help. So if I send my truck out to get aligned are they gonna replace them anyways>??? Or should I just put them in myself. I can work on just about any other part of the Lightning or any other vehicle for that matter. I just don't shine on front suspension. I really appreciate you folks answering my questions. -Mat-
