Should I stop using synthetics?
Old Jan 22, 2003 | 10:07 PM
Rayden's cloud's Avatar
I'm storing my truck up for the winter and was about to change my oil today. I don't know if I should keep using synthetics since my truck is over 70K miles. Is there some point where its best to stop using synthetic oils? If so, what weight oil are you guys using? Just curious..
Thanks!
Old Jan 22, 2003 | 10:16 PM
Jay Lincoln's Avatar
I don't see any reason to stop. I ran the stuff in my 95 cobra right up until I traded it for the Lightning. 130K miles, and never had a valve cover off.
BTY, I changed to 10W30 at about 20k. In the colder climates, you might want a 5w30. I don't like the idea of running a 5w20 in any performance application. It is just too light an oil for a heavy load and higher RPM.
Old Jan 22, 2003 | 10:17 PM
Suavy's Avatar
I never thought about not using synthetics. I have 89K and 3 race seasons under my belt and am happy to report Suavy is still runing great!
Suavy
[IMG][/IMG]
Old Jan 22, 2003 | 10:21 PM
NateTrun2's Avatar
It's the opposite way. In trucks with less miles say brand new till 30,000 miles they say your not suppose to run synthetic. the ultra lubracation properties cause rings not to seat properly. This was in the road racing world of super bikes. It's different for car engines though. Ford uses it so why not?
Old Jan 22, 2003 | 11:34 PM
cpeapea's Avatar
well, if you burn oil then adding a synthetic will only make this worse being that synthetic oil is slippery enough to get by a worn ring. otherwise use it forever, it helps a lot to keep your engine in tip top
Old Jan 22, 2003 | 11:37 PM
Green_98's Avatar
I dont plan on stoppin it ever cause in cold weather it lubricates great. Id keep it up
Old Jan 22, 2003 | 11:41 PM
SCOTTSBEATER's Avatar
Another vote for staying with synthetic. Heck, I heard Gator uses alot of synthetic things around the house, even the bedroom
Old Jan 23, 2003 | 07:51 AM
..Thats funny!
Thanks alot guys.. On with the synthetics!!!
Old Jan 23, 2003 | 08:02 AM
yysenhimer's Avatar
I ran synth on my mustang on engine trans and rear and ran the quickest times. Never had a problem even with high mileage.
