setup to run low 12's without Nitrous???
Old Jan 22, 2003 | 07:57 PM
got hp's Avatar
I'd like to keep the stock exhaust and do it on street tires (sub 1.9 60') without the use of nitrous.
Is it possible or am I dreaming?
Actually just looking for a 12.3 since altitude correction for me would make it a 12.9
Any input would be appreciated.
Old Jan 22, 2003 | 08:00 PM
Don's Bolt's Avatar
Letts see
Lower Pulley - 6# or so
Chip
Filter
Traction bars
Electric fan
Cobra water pump
Throttle body
Maybee
a upper pulley
Line mod or valve body
Old Jan 22, 2003 | 08:03 PM
got hp's Avatar
is a 6# pulley safe to use on a daily driver?
What is the difference in power vs a 4#?
I already have the chip, fliter, TB so I'm half way there!
Old Jan 22, 2003 | 08:07 PM
ICULOKN's Avatar
I did low 12's alot and high 11's a few times with these:
PSP 4-Way Chip
PSP 6lb lower
PSP Filter
PSP Factory Tech Valve Body
PSP Caltrac Bars
PSP Headers & Midpipes
Bassani Cat Back
I ran the best of 11.95 on slicks and a 12.39 on 22's...
And I drive it all the time 24,000 miles hard.
Old Jan 22, 2003 | 08:09 PM
yysenhimer's Avatar
I did low mid 12's, see sig.
Old Jan 22, 2003 | 08:15 PM
Suavy's Avatar
Hey Dude, whats a super fliper?
Suavy
[IMG][/IMG]
Old Jan 22, 2003 | 08:19 PM
Don's Bolt's Avatar
There are a lot of guys running a 6# pulley on there daily driver.
I might sugest a interchangable pulley and run a 4 on the street and a 6 at the track.
Just make sure you comunicate with your tuner.
Old Jan 22, 2003 | 08:34 PM
mecca's Avatar
Im running a 6lb'er on my daily driver. About 7,500 miles on the 6lb'er, and still going strong! Just make sure your chip is burned for it...
-Mike
Old Jan 22, 2003 | 09:12 PM
Rob_02Lightning's Avatar
I ran 12.8 with a Filter-chip-n-my 4lb pulley on worn F-1's
for the next run CECIL APRIL 12th
I now have 28" Hoosier's, a 2-3lb Upper, a Plasma Booster, an Accu-Fab Throttle Body, PSP Traction Bars and a Drive Shaft Loop.
I better knock off at least 3-5 tenths or I'll be pissed
Considering I still havent addressed any cooling mods like a fan, cobra pump, or cool can, not to mention the tranny mod, I'd say I'll still have a little more to pull out if the above doesn't get me to my goal
Old Jan 22, 2003 | 09:39 PM
yysenhimer's Avatar
LOL Superchips Flip Chip. Didn't want to write the whole thing out.
IMO a 6# for the street is fine. As Don's Bolt said, just communicate that to your tuner.
Old Jan 22, 2003 | 10:16 PM
cyntaxx's Avatar
both JeffsLightning and Struckby99 have done low 12s (12.3 range) with:
6# and most of the bolt-ons on ET Streets. I think StruckBy99 ran a 12.3 with a 6#, filter, BfB diablo chip, e-fan, lakewoods and ET streets.
Old Jan 22, 2003 | 10:27 PM
Silver_2000's Avatar
I ran a couple 12.2's with only 4# pulley and other mods... You will need an EXCEPTIONAL traction at the track to get that far in the 12's on street tires.
Doug
Old Jan 22, 2003 | 10:33 PM
TXSVTLIGHTNING's Avatar
12.29 @ 110.55 w/1.80
12.31 @ 111.33 w/1.85
4 lb lower
Flip CHiP
Cone Filter
Accufab T/B
Elec. Fan kit
R waterpump
Torque Bars
Line Mod Valve
Stock Converter
Stock Exhaust
Stock Internals
Rick & Erin
2001 Lightning 12.29 @ 110.55 w/1.80 (4,650lbs)
2003 Mach 1 13.60 @ 101.80 w/2.13 (3,630lbs)
Old Jan 22, 2003 | 10:42 PM
frank2's Avatar
my problem was traction,switching to a 6# pulley in the spring
