can i use ArmorAll on my tanu cover?
IMHO
don't put anything on the cover or anything but the tires.
once you do it once, you'll HAVE to continue to do it forever, or it will actually look worse than if you never touched it. plus all of the grease running down the paint job if it rains sucks.
just my .02
later,
chris
just my .02
later,
chris
Superfords is wrong. UV protection is great and stops fadding and deterioration. They will NOT last longer or LOOK anywhere near original without a UV protectorant, unless you park inside and never take your truck out in the sun. My truck sits outside 24 hours a day. I have never seen any "grease" run off mine from the 303. I donno, maybe it just doesn't stick to the zaino but I have never had any problem with the 303.
ganiman--as I stated above the Extang product is 303. 303 makes it for Extang. If you don't believe that call 303 and ask them and they will tell you that.
noelvm
noelvm
Thnx for the info Noelvm,
I read thru the thread pretty quik and must have missed what you posted.I'm gonna order a gallon of that 303 since its the same as extangs product.Extang only sold the small pump bottle.
Quantity rules!..Is my extang tonno the only one that warned against using silicone oil and petroleum distillate protectant products? Or am I the only one to read the instructions
Frank
Frank
I use a product called nu-vinyl the stuff works great. And when it rains it don't run down the body like armor-all, it last a long time to. A good month in the summer heat. I put it on and rub most of it off. NU-VINYL at walmart like 4 bucks a bottle
krueger
krueger
Frank
Frank
Westleys Black Magic tire shine works great on the cover.
I do mine maybe 3 times throughout the summer and it looks
great. I wash my truck "everytime" I drive it and this stuff stands up to all the washing.
It comes in a clear spray bottle. It fills all the texture in the cover and is really not hard to apply. Leaves a great shine also.
It takes a lot less rubbing to remove the excess than you would think. And when it rains you do not get and oily run off on the fenders and tailgate.
Marc
Marc
Dont get ya Tim Skelton.
Whos "They" And when did I say "they" recommended something that would harm a tonno?I did say,"Is my extang tonno the only one that warned against using silicone oil and petroleum distillate protectant products"?
I'm missing the point
Frank
Frank
Well...it was great to find this thread. I used the Black magic stuff and after I washed the truck and after a week later and a rain storm...it was all over the sides of the box. Garbage!
I'll go with the 303 stuff or something similar that I can find without the petroleum disillates in it.
Thx for the advice, Folks!
Paul G.
Paul G.
