Heim joint help needed
Old Jan 21, 2003 | 10:37 AM
Tim Skelton's Avatar
Originally posted by Ruslow
Tim what yo need is made by a company that markets seal ends under 'seals it' on the bar there should already be one set.As for using teflon that works but you still have the dirt getting into the joint and wearing it out.The sels it s' come in sizes from 1/4 to 3/4 but there is no way to lube them just seals the end.Stan
Seals It looks like the ticket:
I can then add some neoprene washers where the outside edge of the heim clicks against other hard parts.
The replacement bar you sent had the same joints on both ends, whereas the original bar had a seal on one of the joints, the diff end, I think. Thanks, Stan.
Old Jan 21, 2003 | 10:40 AM
Originally posted by Rob_02Lightning
Tim, that is a hot set-up
Thank you, sir. That's an old picture, too. I have added other parts and painted (undercoated actually) the axle and all surrounding surfaces. It's a shame that all of this work goes unnoticed--my truck looks completely stock from the outside.
Old Jan 21, 2003 | 10:50 AM
Originally posted by Grey03
Contact your local Snap On tool guy and buy some 3/8 ths air ratchet protective heads. They will not only look good, but they come in different colors.
Cool! And cheap ($3) too:
Old Jan 21, 2003 | 12:48 PM
captainoblivious's Avatar
Ooh, these and the ones that Stan posted look like the was to go to keep them clean.
Old Jan 21, 2003 | 01:15 PM
awhittle's Avatar
A little FYI
Don't lift the rear of a car by the center of the dif. The tubes are relitivly thin wall and you can knock the entire rear end out of alignment. Pick up at the spring mount.
AW
PS nice truck
Old Jan 21, 2003 | 02:11 PM
LightningTuner's Avatar
Hey Tim, sorry to jump on your post here, but could you please call me when you get a chance regarding a non-related issue. 631-821-3622. Tell Lisa I'm expecting you. Thanks a bunch.
