NEED Help!!
Old Jan 17, 2003 | 01:22 PM
Ruslow's Avatar
NEED Help!!
I need help in finding some bearings for the back of the Eaton bower that is on our trucks.I am trying an experiment and had to remove them the size is, 17mm shaft,length is .872 or 22.148mm,and outside Dia. is 1.063 or 27mm,it is a caged needle bearing with a seal on one end and open on both.Thanks Stan
PS I have treid some of the brg sites and can get close but no cigar.
Old Jan 17, 2003 | 01:24 PM
99svtlightning's Avatar
Can you get them from Eaton? What about MagnaCharger, don't they use the 112 on some of there applications?
Old Jan 17, 2003 | 01:35 PM
Ruslow's Avatar
I have a call into eaton but I feel that it is a ford only designed brg.same with the seals no idetifing numbers to be had and the design is somewhat similair to those used in A/C compressors.Thanks Stan
Old Jan 17, 2003 | 02:07 PM
Don's Bolt's Avatar
Here are a few places you can call
Magnuson Ph (805) 642-8833
Eaton Tel: (616) 781-0200
NSK Bearings Corporation
Ann Arbor, MI 48105
Tel: 734-913-7500
Fax: 734-913-7740
1-800-727-3731
http://www.nsk-corp.com/page.asp?ID=164
http://www.bearingsdirect.com/
http://products.skf.com/
http://www.bearingssupplyco.com/
Old Jan 17, 2003 | 02:23 PM
Turbobo's Avatar
Don's got you the good info. You can also visit here to email the manufacturer:
http://www.magnusonproducts.com/
Old Jan 17, 2003 | 02:27 PM
Don's Bolt's Avatar
I beleve NSK makes the bearings for eaton, at least thats what they say on the Thunderbird SC forums.
Old Jan 17, 2003 | 02:29 PM
RTKILLA's Avatar
My one buddy owns a shop that does tons of work on eaton blowers for all kinds of cars. He's sure to have what you need, but he's not on AIM right now. When I get the info I'll have him give you a jingle.
Old Jan 17, 2003 | 02:53 PM
Don's Bolt's Avatar
If your in a real bind, and if your truck has a 2001 bolt pattern for the suppercharger you can borrow my stock blower. My truck is at Jims shop and I know he has a truck ot two to do before he can work on mine. By the time he gets to my truck I may have a new KB anyways.
I will be in NJ tomorow, so if you need it real bad I can have them send it out on monday.
Old Jan 17, 2003 | 03:40 PM
Ruslow's Avatar
I have tried emailing Eaton and INA they are the ones that make the rear bearings the roller bearings are NSK but the rears are the tough ones.
Thanks Don for the offer but I have a few blowers to play with that is not the problem.I am trying to redo the blower so I can lower the discharge temps.I have a coater that says he can coat the rotors and case and drop the temps an easy 30 degrees.
And with the other things I have done to it I should also increase the volume of air going thru it.
Hope to have it ready to bolt on before I go to Jims in Feb so some testing can be done with it.Stan
Old Jan 17, 2003 | 06:34 PM
Ruslow's Avatar
Well magnuson can do the bearings but they won't sell them to me,so I have to ship the case and they will install the bearings cost on the bearings................10 bucks for the pair.But 70 to install and I already have them out! Plus shipping and all will not be cheap.Stan
Old Jan 17, 2003 | 10:07 PM
Silver-Bolt's Avatar
Stan if you can shoot me some detailed photos I may be able to cross reference and locate you some.
Old Jan 17, 2003 | 10:13 PM
Ruslow's Avatar
Silver thanks for the offer I hope that you can.But I have a strong feeling that it is a ford only bearing made for them by INA since it does not show up in the cat.I can get close but I have a feeling that they have me on this one.Stan
Old Jan 18, 2003 | 10:19 AM
reality1's Avatar
Stan,
You have mail.
Old Jan 18, 2003 | 01:37 PM
blown318's Avatar
