Dyno results, have questions...
Old Jan 16, 2003 | 08:20 PM
Lightning#838's Avatar
I went to REM and Paul tuned my truck for a little while and this is the best combo we could get......
What's holding the horsepower down? I've got very high torque numbers but why is my horsepower so low. I was expecting aroung 10-15 more hp. But overall i'm very happy .This is on a Mustang dynometer. I've been told that this equation will convert your numbers to a Dynojet....
(Mustang HP X .9) / 2615 + 1 X Mustang HP = Dynojet HP
All feedback apperciated
-Brian
*EDIT*
My mods are
2# upper
4# lower
Filter kit
90mm mass air
Ported Plenum
Borla Catback
Factory Tech valve body/ tranny pan
Old Jan 16, 2003 | 08:39 PM
LIGHTNINROD's Avatar
What were your a/f ratios? Are you tuned really 'rich'?
Dan
Old Jan 16, 2003 | 09:32 PM
Not sure...didn't get that printout, i was tuned really rich, but I'm sure it's within the normal range, 11 to 1..........
No one else???
Old Jan 16, 2003 | 09:48 PM
ganiman's Avatar
Hey Brian,
I had the white supercrew that was at REM today.Did you notice on the graph it only showed up to 4500 rpm's.My graph did too,which would explain only 8-8.5lbs of boost.At 5200 rpm I normally see 10-10.5lbs. My max hp @4500 was 293.1 at the wheels.Is 293hp enough to push a 5500-5700lb truck 13.9 in the 1/4 mile?? Seems weird.
See you around,
Frank
Old Jan 16, 2003 | 09:49 PM
SLVRLTNG's Avatar
I had my truck on a mustang dyno with my REM diablo chip, a 5lb lower, and ram air setup. I made 401.2rwhp and 461.8rwtq. According to your equation that's 456rwhp on a dynojet.
Old Jan 16, 2003 | 10:06 PM
See, your almost have the same mods I do, and your making 45 more hp, but 30 less torque, uh, why
Old Jan 16, 2003 | 10:10 PM
SLVRLTNG's Avatar
Could have something to do with the rpm readings, mine are at 4750 and 4500 while yours are taken at 4250 and 3000. I would give Paul a call, I'm sure he can explain everything to you, he's good at answering questions...smart guy Paul is ....JR
Old Jan 16, 2003 | 10:27 PM
Oh, i know, been there a million times, it's not that he didn't make a big change in my hp and torque. I gained 20 rwhp and 70 rwtq by just putting the truck on the dyno and having him tune it, compared to the mail order chip. I can't believe the power this thing now has. It's a whole new truck
Old Jan 16, 2003 | 10:28 PM
mecca's Avatar
Hey Brian,
Nice numbers man. Im sure you thinkin the numbers are low is because of the Mustang Dynometer...
-Mike
Old Jan 16, 2003 | 10:32 PM
TZrider's Avatar
It's 10.30...and I'm too tired to give a long explaination, suffice to say there is a very good one and it has to do with the test procedures that I as a tuner prefer to use. I'll post an answer for you all later...For now, just ask Brian and Jon how there trucks run
Paul
Old Jan 16, 2003 | 10:37 PM
SLVRLTNG's Avatar
Paul
My truck runs awesome, thanks to Paul......tracke are closed for the winter, but I'll be ready for spring......deep into the 12's are on the way...........
