lower pulley help PLEASE
Old Jan 15, 2003 | 04:37 PM
hslightnin's Avatar
i cant get the engine to stop from rotateing when pulling on the pulley.
Old Jan 15, 2003 | 04:39 PM
mrinaldi's Avatar
Re: lower pulley help PLEASE
You need the trans/converter lock-up tool...
Old Jan 15, 2003 | 04:41 PM
hslightnin's Avatar
any way else?
Old Jan 15, 2003 | 04:50 PM
mrinaldi's Avatar
Well, not really without risking damaging something....You could probably make the tool yourself..It is simply a piece of metal, 1/4 inch thick or better with two holes in it on each side. You have to go under the truck remove the inspection plate (2 bolts), and you can see the converter. You would place the tool on one of the converter studs, and line up the other hole with one of the holes from the bolt you removed from the inspection cover, and put that bolt back in. This will keep the engine from spinning. Remember that the pulley is reverse threaded. Good Luck...
Old Jan 15, 2003 | 05:24 PM
hslightnin's Avatar
sounds good thanks
