head swap/ head bolt question?
Old Jan 15, 2003 | 03:18 PM
collins8's Avatar
Banned
Plan on swapping my heads for a set that I am having ported.
When I go back and reassemble everything it would be nice to go with the ARP head studs but it looks like the engine needs to be out of the truck to use the studs. Unfortunatley ARP does not make head bolts just the studs. Has anyone swapped heads and completed the job going back with studs leaving the engine in the truck? It looks impossible to do.
Rob
Old Jan 15, 2003 | 03:25 PM
Don's Bolt's Avatar
I would think you have to have the engine out.
You may be able to place the head on and screw the front and midlle studs in. I don't know how you would get the rear ones in with the head on.
Old Jan 15, 2003 | 03:41 PM
easterisland's Avatar
I'm not 100% sure, but I think Sal has done head swaps with the studs installed and engine in the truck.
Old Jan 15, 2003 | 03:44 PM
collins8's Avatar
Banned
As much as I hate to, I may end up going back with the Ford head Bolts or pull the engine.
Old Jan 15, 2003 | 05:24 PM
cpeapea's Avatar
i think it is possible to do but a major pain in the you know what, and i think you are supposed to replace the head studs after they have been removed, i think thats what is says in the ford tech manual
Old Jan 15, 2003 | 05:46 PM
Originally posted by cpeapea
...i think you are supposed to replace the head studs after they have been removed, i think thats what is says in the ford tech manual
Since when did Ford start using head studs? Where in the tech manual?
Old Jan 15, 2003 | 06:17 PM
cpeapea's Avatar
CAUTION: Cylinder head bolts must be replaced with new bolts. They are tighten-to-yield designed and cannot be reused.
straight from the tech manual from the dissassembly section, i meant to type bolts but just forgot...sorry
