?'s on Valve Body Install, 4x4 pan and tranny fluid change...
Old Jan 16, 2003 | 01:43 PM
yysenhimer's Avatar
Originally posted by flyingpig70
Can I ask, why not mercon 5?
Mercon 5 is not compatible with Mercon.
Our manual says not to mix them, and not to use Mercon 5. I asked a few trannie gurus some time ago and they all basically said that some big problems MAY result from using it. IMO it is not worth taking the chance on something that you are not gaining anything from using. I would rather use a synthetic fluid that is Mercon compatible.
Old Jan 16, 2003 | 03:44 PM
JBRIII's Avatar
Mercon V nd the 4R100
From what I understand the Mercon V has an additive that was designed for the 4R70W shudder and will eat up your clutch packs in the Lightning 4R100 Tranny.
John
Old Jan 16, 2003 | 03:52 PM
Cali L's Avatar
Don't forget to remove the little magnet from the old pan and place in the deep pan. Forgot that the first time around. I think I put in like 13.5 quarts or so for both the TC and tranny. Just get RP Max ATF and don't worry about the whole Mercon debate.
Old Jan 19, 2003 | 05:58 PM
ShaneMcKenna203's Avatar
I just got back from work, and it is, Dexron III/Mercon im sorry to confuse anyone and make this harder than it is... But it is mercon tranny fluid i have at work... Thanks again for the help, Shane McKenna
