Help!!!!!!!!!!!!!
Old Jan 12, 2003 | 08:06 PM
Cali L's Avatar
Help!!!!!!!!!!!!!
I can't get the new belt on after a 6# install. It is the correct belt (both pulley and belt from PSP). I've tried it all, even taking an idler off and trying that. I've mainly tried to get it on the passenger idler last after pulling down on the tensioner. Is there a secret??? Help!!!!!!!!
BD
Old Jan 12, 2003 | 08:09 PM
Probleminfected's Avatar
brake the stop pin off,
i'm still using a stock belt w/ a 4lber
i had to brake my stop pin off to do this though
Old Jan 12, 2003 | 08:18 PM
Don's Bolt's Avatar
Ya sounds like you have to break the stop.
Also it sounds like you were doing it right, get the belt over the upper pulley, then push the tensioner, and slip the belt inbetween the tensioners.
Old Jan 12, 2003 | 09:10 PM
Cali L's Avatar
Thanks for the help. I never thought of breaking the stop off. I went out and tried one last thing waiting for replies. I took the driver idler off and managed to slip it back on when the tensioner was on the stop. So the bi!ch is on but has absolutely no play. Hope there isn't such a thing as too tight
BD
Old Jan 12, 2003 | 09:14 PM
i'd still break it.
you don't want a belt thats to tight
