caltrac install question
Old Jan 12, 2003 | 01:29 PM
soonerlightning's Avatar
Question caltrac install question
I have a set of the caltracs that I bought used from ITSOEZ.. I tried to install them last night and man was that a chore.. Do you have to use a new leaf spring bushing? I was looking at the hanger and it does not look like it will open up wide enough to put the caltracs front bracket and the leaf spring in. Are the bushings that come with the caltracs supposed to be narrower than the originals?
Old Jan 12, 2003 | 01:32 PM
ICULOKN's Avatar
Re: caltrac install question
Originally posted by soonerlightning
IDo you have to use a new leaf spring bushing?
You may have not got the right bushing with a used set. You should replace the Rubber bushing with a solid mount Aluminum one that come swith the kit. The person that sold you the used ones may have left the Aluminum one in their truck. Sal can get you a set of the Aluminum ones.....
Old Jan 12, 2003 | 01:42 PM
thanks for the help...
Old Jan 12, 2003 | 01:54 PM
ICULOKN's Avatar
No problem, its a common thing with the Caltracs, most drill out their stock bushings to install the Caltrac ones. SO when you remove the bars you have to leave the caltrac ones.
Old Jan 12, 2003 | 02:05 PM
ahhh.. I was wondering about that.. I tried everything lastnight.. So are the bushings that caltracs send actuall narrower than the orig.? Seems like they would have to be.
Old Jan 12, 2003 | 03:23 PM
Don's Bolt's Avatar
It is a 2 peice bushing
It has a outer and a inner sleave.
Old Jan 12, 2003 | 03:31 PM
LightningTuner's Avatar
The aluminum bushing is the same width as the spring eye. The steel sleeve that goes inside it is wider. It is the width of the perch. The plates slip over the steel sleeve, then when the bolt is tightened down, there is clearance that allows the plates to pivot. Hope this helps .
Old Jan 12, 2003 | 08:20 PM
thanks for the help Sal..
