SVT Center badges?
Has anybody bought these from a ford dealer? I searched a found a part # on here, but was told that this is an engineering part # and was probably the one on the back of the cap. They couldn't cross reference and searched but only found the silver caps.
I also tried KarKraft, but they no longer carry them. How do I order from Tirerack if I can't get them from a ford dealer? Do I have to call them?
Thanks for the help,
Brad
Brad
I bought this set of wheels and they arrived today but I have not changed the center caps out and mounted them because it is just too cold to turn a wrench tonight! I will be putting them on in the morining and putting the replacement centers on them too. I cant stand the bolts on those things! But the rims are great!
Those are the centers I am gonna use there in the corner of the picture.
when i had a set of wheels powdercoated in black, I took the silver caps and removed the "SVT" centers and had the center caps painted black, then I used a ton of epoxy to re-install the SVT caps. They are held in EXTREMELY well, I thrashed one trying at first.
With a lot of patience and steady hand with my dremel I was able to get them done. It's been almost a year, but I recall when the center cap is off there is 5 small holes that you can see the back off the "SVT" piece I basically connected the dots, lol and cut almost all the way through, what very little plastic that was left, I used my pocket torch to heat it up and pressed it but hand. Like I said it's a PITA, but it worked {shrug}
Once done, I made sure I marked the caps & centers so I got them all back to the correct one and used epoxy to hold them back in place. As far as I know, new owner of those wheels hasn't had anything happen with them.
I think the black would be even cooler on a white L
Rick & Erin
His~ 2001 Lightning 12.29 @ 110.55 w/1.80 (4,650lbs)
Hers~ 2003 Mach 1 13.60 @ 101.80 w/2.13 (3,630lbs)
The extra set I passed to Vin where from Tirerack. The part numbers I posted up are valid if you want to order them from Tirerack. I have no idea what tirerack charges for them. I do know they ship them seperately, hence I had one set of chrome wheels, yet two sets of caps.
Daniel
Daniel
Re: SVT Center badges?
Originally posted by 78f1hundo
I have 20" factory chrome replicas and I want the center caps to have the factory SVT not the lightning bolt.
Where can I get these?
Thanks,
Thanks,
http://svtcustoms.com/
Check it out.
