X or H pipe
Old Jan 4, 2003 | 11:50 PM
frank2's Avatar
Question X or H pipe
which one is it guys and gals? I hear stories on each but which one are WE using out there and why?
Old Jan 4, 2003 | 11:52 PM
cpeapea's Avatar
i got the notion that the x pipe was just an updated h pipe, but im not sure.
Old Jan 5, 2003 | 01:24 AM
soap's Avatar
Frank,
Use an X-pipe it flows better.
--Joe
Old Jan 5, 2003 | 12:10 PM
Ruslow's Avatar
they both have benefits.to use an x pipe you really need all the room under the truck that way it is a true x.The idea of the x is to scange or create a vacum on the other pipe to help pull the gases out from the forward part of the pipe and alos to even the flow out more.The h pipe at best equalizes them and not to well either.since it has no position for flowis more likd a balance tube.The modified x as I call it like JDM and bassani use is the best for the restrictions that are under the trucks .In my case since I relocated the tank I had freedom to use the real x but its not to easy to do.Stan
Old Jan 5, 2003 | 05:00 PM
Neal's Avatar
Cool
HI!... Use the "X" pipe. This is my set-up.
https://www.f150online.com/galleries...-793-37311.jpg
https://www.f150online.com/galleries...-793-37312.jpg
https://www.f150online.com/galleries...-793-29786.jpg
Old Jan 5, 2003 | 05:18 PM
Tim Skelton's Avatar
Everything you ever wanted to know about X and H pipes (warning to dialup users-link is to a PDF file--give it a minute): crossover tech
Old Jan 5, 2003 | 06:06 PM
Ruslow's Avatar
here is mine that I did.Its in 3 inch mandel bend tubing.It has been posted before.Stan
