Roush on 03 L
Old Dec 31, 2002 | 04:14 PM
ShadowBolt's Avatar
Roush on 03 L
My Roush lowering kit came in (less the front springs) and now I wonder if the kit will make the truck sit flat since the 03's look to be very high in the rear.
Jerry
Old Dec 31, 2002 | 04:31 PM
superfords's Avatar
isn't the roush kit rear leaves? if so, it doesn't matter how high the truck is to begin with, it will lower all trucks TO the same height, not by the same amount. your truck will be sitting high in the front if you just do the rear springs...
Old Dec 31, 2002 | 06:11 PM
ShadowBolt's Avatar
Thanks. You are right the rear spring are in the kit. I am doing the complete kit.
Jerry
Old Dec 31, 2002 | 07:47 PM
03LightninRocks's Avatar
Jerry,
Please post some pics as soon as you get it done. I am in the same situation with my 03 and trying to decide which kit to go with. The springs sounded attractive to me also.
Thanks,
Rocks
Old Dec 31, 2002 | 08:14 PM
BDAZSVT's Avatar
Roush says the 40% sale ends at the end of Jan.
Old Dec 31, 2002 | 08:19 PM
LatemodelRacer2's Avatar
whats roushs website?
Old Dec 31, 2002 | 08:23 PM
Twisted99's Avatar
www.roushparts.com
Better yet do yourself a favor and call Eric@Roush 734-466-6253
When I bought mine it was $675.00 and $75.oo to ship...
Old Dec 31, 2002 | 08:44 PM
Twisted99's Avatar
Here is the Roush kit on my 01...I do have Drop shackels on the rear but only added 1" for a total 4.5 ....
Wheel well lip to center of wheels were 17" all the way round...
One warning...When I put the front shocks on the lower mount has two holes that slip over the factory bolts/studs....The holes on the shocks were a bit wider than the studs. The lower bolts are pressed in...put a couple nuts on the thread to protect them and use about a 5# hammer or heavier to tap one to unseat it. Then just pull it back into place after stabbing the hole...you may not have this situation..I did..not so bad..One more thing..start savin` for big brakes..you'll run out of road a whole lot faster..Not that that's a Bad thing...
