Final word on pulleys without chip?
Old Dec 29, 2002 | 03:35 PM
Stormyday's Avatar
Is there any?
Is a 4lber safe?
Old Dec 29, 2002 | 03:39 PM
cpeapea's Avatar
supposedly only a 2#er is safe, i would go beyond that without a chip bro
Old Dec 29, 2002 | 03:43 PM
ICULOKN's Avatar
Some have tried many things....
Its up to you really and what you feel safe with. Each truck is different....
Old Dec 29, 2002 | 03:52 PM
Justin@JDM's Avatar
Banned
Stormy,
I would only recommend sticking with the 2LB with no chip. The factory truck runs rich so you could throw a 2LB on and it won't lean it out enough to do any damage.
Justin@JDM
Old Dec 29, 2002 | 03:53 PM
Hamrhead's Avatar
I have a 2lb. w/ no chip and the truck runs great. Seeing 12psi on my Autometer boost gauge.
Rob_02Lightning's Avatar
There's some post over at NLOC that are extremly interesting about this matter. Some are running NOS, some major boost, none with a chip ??? I truly wonder myself sometimes if the factory set up can handle and adjust just as good or better.
Don't get me wrong I have two chips and 4 differant programs and believe in them. I'd be lost with the factory rev limiter, having torque reduction back, and crapy shift points with mushy shifts.
NOT TO MENTION THE HP ADDER WHICH IS THE TIMING.
But one still cant help but wonder ???
Here's the link
http://www.nloc.net/forum/showthread...5&pagenumber=1
Old Dec 29, 2002 | 04:25 PM
Blown93's Avatar
Rob I have read those also and It does make you wonder... Still I'm chiped and I would rather be safe like you.... At least I hope I'm safe...........
PEaCE............ Happy Holiday
Old Dec 29, 2002 | 05:17 PM
Probleminfected's Avatar
#4 w/o chip for a month, running better then when i had a chip
Old Dec 29, 2002 | 05:19 PM
Tim Skelton's Avatar
Chip for safety? I think the opposite is true--run the pig-rich stock program for safety (at the expense of a few ponies).
Has anyone ever reported detonation or detonation-related engine failure running a larger pulley and the stock chip? In the NLOC thread, no one did, yet many, many people have experienced detonation with a chip, irrespective of boost levels.
Ford has to warranty these things for 36,000 miles. A tuner does not have to warranty them for a day.
Old Dec 29, 2002 | 05:21 PM
mrinaldi's Avatar
Do you have any timeslips to back up that statement?? No tuner bashing here, but maybe you did not have a good program to accomodate all of the mods that you have...just my .02
Happy New Year...
Old Dec 29, 2002 | 05:26 PM
Happy New Year...
i don't mean better as in 1/4 mile times.
i mean i dont get anything pinging anymore.
my chip was tuned for 89 octane and i'd always put in 92 and still get pinging. thats what i mean by running better
Old Dec 29, 2002 | 05:28 PM
mrinaldi's Avatar
sorry dude....Did you run the truck with and without the chip with the same mods???If so, what was the e.t. and mph difference???
Smurfslayer's Avatar
There isn't one....
The truck comes from the factory with computer programming that is a compromise of economy, safety, performance & reliability. EVERY modification you make that affects the delivery of power is cutting into the saftey net of the factory programming. Some more than others. And, the golden rule applies - just because Joe sixpack did it on his truck, doesn't mean your truck won't blow up after one day - they're all different... Basically, the trucks don't 'adapt' per se, it's that they're set up to run rich to begin with, and don't have the timing set for maximum performance in optimal weather conditions. That's because chances are, you will drive the truck in non optimal conditions (remember, it's fast but it IS a truck...) If you get crazy with boost, you will likely have to change plugs, but up to about 4 extra # of boost, the stock programming should be ok - should being the operative word... some accurate A/F ratios would be needed to tell for sure.
If you do a search on 'burnt plugs' or the like, almost all of the burnt plug victims were running a chip. Vendor (if listed) didn't seem to matter, and boost ran the entire spectrum. I'm not saying chips are bad, or that they don't work, only that they sacrifice reliability for power.
Old Dec 29, 2002 | 05:31 PM
you know, i still haven't made it to the take.
JJ's is going to do some testing w/ and w/o chips when the tracks open up again.
Old Dec 29, 2002 | 05:34 PM
mrinaldi's Avatar
Well good luck, and be sure to post the test results...I am sure that alot of people would be curious to see them....
Have a safe and healthy new year..
