Nitrous express
Old Dec 28, 2002 | 07:45 AM
Marc Carpenter's Avatar
Nitrous express
Anyone using Nitrous Express have any pictures of your install?
Not really sure where to run one of the fuel lines, and one of the selonoid wires. ( Used system and no instructions)
Thanks in advance for your help.
Marc
Old Dec 28, 2002 | 10:49 AM
beefcake's Avatar
lol, marc, maybe i can help a lil,
you have 2 fuel lines, what should be the shorter line, goes on the passenger side fuel rail toward the back, the other line goes right into the psp nitrous plate
as far as wires, not sure which one your referring to, is it one of the 4 clipped wires or is it a wire with an end on it.
the ground to the solenoid will go nicely on the power steering box bracket bold. I would recommend some sandpaper to insure a good ground is gotten. The longer black wire with an end should be your power wire, that will go on the bold on the back of the power distribution box.
the 2 green wires (i think they are green) will go inside the cab to run to your activation switch and purge switch,
the red and blue wires will route under the side of your truck along with the long nitrous line to match up to the clipped blue and red wire at the bottle heater.
Old Dec 28, 2002 | 01:43 PM
smokingozzy's Avatar
Wink
Marc, what are you up to now! Jim
Old Dec 29, 2002 | 06:20 AM
Thanks Terry, I think I have it right now. The wheels really cleaned up well. Truck looks totally different now..Much better !!
Looking for that 11 sec. pass in early April.
Jim, what makes you think I am up to something? Just adding a little liquid vitamins to enhance performance.
Marc
