NGS Scan Tool
Old Dec 20, 2002 | 09:36 AM
Silver_2000's Avatar
Originally posted by jefflaws
If he means for 1K more he could get a NGS, then that will get you the ability to work with all the modules in the vehicle, including the PCM, GEM, ABS, HEC, RCM, etc... You can also program your keys , do parameter resets if you swap processors etc. You can also do all the active commands and component tests within each module. For example, if your windshield washer were to quit spraying, you go into active commands under the gem module and command the washer pump to run. If it does, you have automatically ruled out the relay and pump and wiring. Then you can monitor the washer switches input to the gem while troubleshooting the switch circuit. I just dont think you can do that stuff with a autotap.
You are right autotap ONLY reads, and resets codes.
BUT $1500 JUST buys the hardware NOT the cards needed for all the tricks you mention. AND if you get the NGS setup , it only works for one make and model of car.
I almost bought a NGS but realised without a "connection" that can get software updates it becomes less than usefull pretty quickly... If the stock market comes back around maybe ill take another look.
8008FA NGS Ford Diagnostic Master Kit $1995 PLUS
81010 NGS Ford/Mazda Flash Kit 2.0 $1195 PLUS
To program keys and PATS - 8008LA NGS Locksmith Specialist's Kit $1995
Included for the amounts above are 1 year subscriptions to the databases needed to lookup and make changes
Old Dec 20, 2002 | 09:57 AM
kidtriton's Avatar
Originally posted by air1kdf
$9,000 for WDS. You guys are out of control. I take it that nobody on this board has one of these.
I have the Actron. Works GREAT for reading and clearing codes. Cost was between 150-200. Works on all ODB2 computers.
Ive got one. At work that is.
Old Dec 20, 2002 | 10:01 AM
kidtriton's Avatar
Doug, where in the world are you pricing that from? I can buy the NGS with the diagnostic card for 1995.00 and then a service (green) card for $150. That will do EVERYTHING ford (programming keys, all module configurations......) plus all the generic OBDII stuff that any other ODB scanner will do. Im pricing out of the rotunda catalog.
Also, when yo u say you can read and clear codes with autotap, is that ABS, RCM, HEC, GEM, too? or just PCM? just curious. I was thinking about buying a auterra kit for my palmV that will do all the generic stuff, but didnt get because it wont do abs and airbag codes, which i work on as much if not more than pcm related stuff. I have just stuck with our NGS.
Old Dec 20, 2002 | 10:44 AM
SSCULLY's Avatar
jefflaws,
Autotap is just the ODBII and Ford specific DTCs ( R/C ).
In addition to the Actron type scanner functions, you can view and log individual setting in the truck like IAT, MAFS flow rate, MAFS output voltage, A/F ratio...etc, but it is not doing what you talked about with the NGS.
Old Dec 20, 2002 | 11:00 AM
The manufacturer-
http://www.hickok-inc.com/ngs/ngsford.html
The additional pieces may or may not be optional depending on what you want to do. Im sure they sell the (2) $1000 pieces for a reason. If the base system did "everything" why would anyone spend the extra ??
The subscription updates are $900 a year
The autotap ONLY does PCM codes as far as I know..
I also heard that Ford is going away from NGS to some new system for new stuff
Question:
IS THE WDS GOING AWAY AND THE NGS STILL GOING TO BE AROUND?
Darryl Hazel:
Robert White - We are looking at extending WDS beyond Jan. 2004. Our current plan is to support NGS through 2006.
Doug
Old Dec 20, 2002 | 11:03 AM
LightningTuner's Avatar
As Jefflaws mentioned, the NGS gives full capability to pretty much everything in the vehicle. This is provided you have the Deluxe NGS kit. The Basic NGS kit just comes with the diagnostic card, and costs around $1600. This will allow you to do datalogging, code retrieval, and lots of other diagnostic stuff, on all the modules in the vehicle. The Deluxe NGS kit comes with the diag and the function card, and some other cables. The function card is the one that allows you to do the PATS stuff, parameter resets, module replacements, and more. This kit is about $1900. If you really want an NGS, get the deluxe kit, because to buy the function card by itself is about $300, unless you are lucky and snag one cheaper off ebay. Recently, Ford switched to 3 cards, a pre-99 diag card, an 00 up diag card, and the function card. A new purchased Deluxe kit will come with all three.
If you are just looking for code and datalogging capabilities, then go with the EASE software (provided you have a laptop to use it with). I like the EASE way more than the Autotap, and even the basic Ford OBDII package has tons more parameters you can datalog than if using an NGS. There are things the EASE will datalog that's not an option with the NGS, and also using the laptop with the EASE, gives you practically unlimited recording (limited only by your laptops hardware), whereas with the NGS, you are VERY limited in recording storage.
Hope this helps.
Old Dec 20, 2002 | 11:14 AM
kidtriton's Avatar
Doug
Actually ford just reinstated the ngs for another good 4 or 5 years of life. My buddy at work just got back from his senior masters cruise and that was one of the seminar topics they had. LONG LIVE NGS!!! haha. Actually its wds that will get the axe first. Not many people ever liked it anyway. They are coming out with new modules for ngs (the bottom half that slides out of it for people who are familiar with it) that will do the new protocols (like UBP) and stuff that the 2002explorer, 2003 expy, and so on use.
I have seen several "deluxe" ngs kits for sale on ebay and they sell for $600-$800 usually. Even if you get one thats screwed up, hickok does a complete refurbished exchange (new cables and everything) for $395 no matter what is wrong with yours that you send in. So you can feel good about buying a used one and if it doesnt work, just get it re-furbed.
Old Dec 21, 2002 | 05:09 AM
Ak.Silver2K's Avatar
Hmmm
Sounds like, for me, the EASE is in a decent price range and offers plenty of monitoring capability plus data logging. Thanks, learned quite abit in this thread.
Mark
Old Dec 21, 2002 | 08:49 AM
JeffsLightning's Avatar
Do you happen to have a link?
Old Dec 21, 2002 | 10:20 AM
kidtriton's Avatar
to what? ebay? there is one currently listed, you have to keep checking to find them.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875333220
and here are some cards
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875048976
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875237094
Old Dec 21, 2002 | 10:24 AM
Yep e-bay link....thanks
