Those with QA1's up front. Install tips needed.
Old Dec 15, 2002 | 10:27 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Gang,
In an attempt to install the front pair of QA1's today, I experienced what seems to be a clearance issue and thwarted completion of todays task.
The bottom of the shock body on a QA1 is much closer to the lower mount that the Bilstein. This caused hole in the control arm to touch the bottom of the QA1 and subsequently not allow the "T" mount to fit on to the lower shock mount bolts.
A set of Tim's (Skelton) install tips were printed and handy but still caused the above issue. An engineer bud had a look and suggested I grind off the unthreaded portion of the lower shock mount bolts in order to gain some clearance. Dont really want to do that unless ABSOLUTELY necessary.
Any tips or tricks would be greatly appreciated.
Stan, Spike, Tim, you have mail.
Bob
Old Dec 15, 2002 | 10:40 PM
GDBY-55's Avatar
I pointed the shock with the adjustment **** toward the engine and they fitted perfect....Hope this helps......
Old Dec 15, 2002 | 11:15 PM
captainoblivious's Avatar
Originally posted by GDBY-55
I pointed the shock with the adjustment **** toward the engine ...
Do that.
And you have to play with the T-fitting. You need to twist it and wiggle the shock. After you get one the next will be much easier.
Ayrton's Avatar
I had the same problem, just compress the suspension a little and work it. Once the shock slips in to place, the second one will be easy.
Old Dec 15, 2002 | 11:40 PM
Spike Engineering's Avatar
Re: Those with QA1's up front. Install tips needed.
Originally posted by Speedin Bob
...Stan, Spike, Tim, you have mail.
Bob
I emailed my tips back to you earlier.
Old Dec 15, 2002 | 11:48 PM
awhittle's Avatar
Bob
I had the same problem on my 2000 L I ended up grinding on the bottom two corners off the shock to gain clearance. Yes it was scary. I was later told that if you pust the shock rod all the way in you can get it in but ...
Hope this helps
Andy
Old Dec 16, 2002 | 03:17 PM
99REDBOLT's Avatar
Question
how stiff will these shocks adjust to because i need a stiffer shock than the bell tech nitro active.
Old Dec 16, 2002 | 04:48 PM
Thanks for the replies guys!!
Will attempt this again this evening.
....Paging Dr. mOdThRaX....
99REDBOLT,
From what I can ascertain what those that have posted their experiences (Spike, thepawn, awhittle, Ruslow, et. al.), the #12 setting is REAL stiff.
I'll post my findings after all four are installed and have a chance to play with the settings.
Bob
Old Dec 17, 2002 | 12:29 AM
Well?
Old Dec 17, 2002 | 12:36 AM
awhittle's Avatar
Bob
Start at about 4 or 5 clicks front and rear for normal street driving.
AW
Old Dec 17, 2002 | 08:02 AM
thepawn's Avatar
Bob,
The trick that we used t oisnbtall the shocks onto my truck was to raise the lower control arm some after we had the shock installed in the location. If we had left the lower control arm down, we were not ablet to get the bottom shock mount to propely fit with the t-section.
Took one phone call to George and about 5 minutes of playing to figure this out after 20 minutes of staring.
Daniel
Old Dec 17, 2002 | 08:57 AM
L8 APEX's Avatar
It is tight, I jack the arm to where it is loaded. Iuuuuuuuuuu turn the shock to the lowest setting, compress the piston most of the way. Use a screw driver to angle the lower T mount and work one side on then the other. Something similar to that will get it in there. I use blue 242 loctite since the nuts don't go back on as far. make sure you reused the stock lower bushsings. They help locate the shock. You have to cut the top tower down to about 1/4", then I cut the bottom in half. The shock hole is almost as large as the supplied bushings.
QA1's scan go from no shock floating to break your teeth stiff.
Old Dec 17, 2002 | 09:00 PM
thepawn's Avatar
I didn't have to cut anything on mine? Did you buy the shocks for a lowered truck or no?
Daniel
Old Dec 17, 2002 | 09:55 PM
Fronts INSTALLED!!
Thanks to Spike and all, both front QA1's were installed in less than an hour.
Following Andy's advice, I set them to 5 and headed out for a 40 mile drive (had to go back to work).
The roads were wet so pushing the truck was a NO NO.
As for comfort, MOST EXCELLENT!! Can't wait to get the rears on and test thoroughly in the spring.
Backing out of the driveway clearly indicated the 22K mile Bilsteins were shot.
as always gratuitous imagery.
install tools (floor jack and jackstands also required)
Thanks again guys!!
Bob
