King Ranch
2005 F 150 KR Keyless door code
Old Dec 28, 2007 | 11:04 AM
rbanga11's Avatar
Smile 2005 F 150 KR Keyless door code
Hello Everyone. New member here. I just bought a used 2005 King Ranch Super Crew with 55,200 Miles for $18,700.00.
I do not have the original door code. Where can I locate the keyless door code hidden in a 2005 ford f-150? How do I reset the code and program a new one?
Thanks for the help.
Old Dec 28, 2007 | 11:14 AM
FordsForMe's Avatar
I think you will need to get it read by a dealer, that is what I needed to do. Dealer did it at no charge. The directions to set it to something else were located in my owners manual.
Old Dec 28, 2007 | 02:04 PM
KingRanchMan02's Avatar
If you can find the module that controls this under the dash, the code is on a label on the outside of it. I know that on the 97-03 models the module was under that dash above the driver's feet. It is a white of very light colored box with the five digit code visible by looking up there. Good luck!
Old Dec 28, 2007 | 03:49 PM
SleepyMax's Avatar
The keycode is on a computer module, located BEHIND the backseat in the '04+ models. Of course, you can spend an hour or so removing the seat and putting it back, or you can take a trip to the dealership.
I took mine in for the same situation, and they wanted $30 to retrieve the code. Hopefully, your dealership is kinder.
Old Jan 2, 2008 | 11:27 AM
ErnScott's Avatar
Sounds like a good deal on your KR.
I had forgotten my code from my 05...and lost the slip with the original #. Dealer retrieved it at no cost and, as mentioned in a previous post, instructions on changing are in the manual.
And welcome to the group
Old Jan 2, 2008 | 06:04 PM
I12AV82's Avatar
I had my dealer read the code when I bought the truck - couldn't find the little card with it from the factory - I'd take it back where you bought it and insist that they provide the code for you.
Welcome to the group, just be weary of the injector problems on the '05s - I had to replace mine not too long ago.
Old Jan 4, 2008 | 06:38 PM
becerraale's Avatar
Thumbs up This realy work
I have the same problem w/ my truck the code is rigth under the dash thank u Man2 for the tip
Old Jan 4, 2008 | 07:54 PM
You're welcome, glad to help out. Keep KRing!
