Warning
i'm not a KR owner but i'm going to guess that either the paint on your roof has started to bubble/peel or the inside edge of your doors/tailgate are starting to show rust. both of these are a very common problem that Ford knows about and should fix under your 5 year warranty. i'm sure these KR owners would like to hear back from you.
yeah it started flaking off on top of the cab probably about 8 months ago i believe it had around 53000 miles on it, ford repainted the top of my cab and i was told it was bad primer (now to me if its bad primer on the cab its bad primer on the whole truck). Well about last december i noticed between the hood and the fender was flaking off the same way.
I have a 2002 supercrew in estate green and I noticed the paint flaked off the roof of my truck about a year ago. The area is about the size of a nickel. Do you think Ford would take care of it. I used the touch up paint to fix it for now.
