does anyone - Tire Balance?
have the problem with there king ranch that when your goin down the highway at about 60 mph or more that the wheel shakes pretty good. Its done this before and the wheels were out of wack, well its not as bad so I think there ok. I have looked in the rims and seen dirt sittin in there but just the back ones would that make it ride rougher. Also when is it time for the first tune up, everyone once in a great while when i step on it there is a small delay, maybe its time for new plugs? thanks.
What size wheels do you have? Are they 20's? If so, you have found your problem. For some reason, F150's don't do well with Plus 3 sizes.
You could do a search on all my posts about it, under RollingRock but brace yourself, you may not like what you find out.
Best of luck to ya.
JP
Originally Posted by Buzzz
The infamous wheel nibble. Your luck if yours is gone. Mine will not go away. Road force balance, rotate tires, different tires, different rims, still there. Dealer says sorry, can't find anything.
Originally Posted by Smiley Pete
Had the same problem on my F250. Vibration still there after Road Force balance. Dealer then put it on a lift and ran it at 55MPH, and noticed that the drive shaft was out of round. Replaced under warranty. Vibration gone.
Just a little tid bit to pass along.
