King Ranch
looking for leather dye for my steering wheel
Old Jan 13, 2007 | 09:59 AM
jetmech23's Avatar
I have a 05 s/c King Ranch that needs some touchup on the steering wheel,it is all blotchy in color. Looking for somewhere to purchase enough dye to touchup the steering wheel,don't need very much.
Old Jan 14, 2007 | 08:33 PM
RollingRock's Avatar
Can you post some pictures so we can help you out?
Have you checked out the leather sticky in the KR section?
Old Jan 15, 2007 | 09:43 AM
jetmech23's Avatar
pictures
Thanks for your reply Rolling Rock (that sounds like a Pittsburgh name)
I am posting some pictures. I did check the stickys and couldn't find any dye for sale. I am stumped I was going to post some pictures but can't figure how to do it. Help please.
Old Jan 15, 2007 | 10:03 AM
plunds01's Avatar
You might want to give ColorNew a call, their website is www.colornew.com to see if they have any recommendations.
Old Jan 15, 2007 | 10:07 AM
I am in Texas....but drink a lot of RollingRock beer.
Best thing to do is to create a gallary and give us the link so we can look. If you were in TX or FL there is a company that can shoot your seats with dye to match and they "specialize" in KR.
They have some before and after pictures listed in the KR section. If you travel down here, may be worth getting done. If not, i think you can fix it yourself with some work.
Build your gallary and upload some photos then give us the link and we'll go from there.
Old Jan 15, 2007 | 11:39 AM
jetmech23's Avatar
Link to Steering Wheel Pictures
*images added - RP*
Old Jan 15, 2007 | 11:51 AM
First glance, it doesn't look that bad and I think you can get it back to normal or close to it with some work.
My suggestion. Go look at posts from RockPick (not RollingRock) and see his posts on the warm water cleaning method. It appears that your discoloration is from oil...body oil and dirt.
I would use microfiber rags for this process but get some warm water and wrap the wheel till it is saturated. Once that is done lightly rub the wheel with the rags...you WILL see dark color on the rag, rinse and keep going. Do this process several times....then this is important. Wait until the leather is completely dry....then put the KR cleaner conditioner on it.
Anyone else want to chime in.
Old Jan 15, 2007 | 12:15 PM
plunds01's Avatar
I'd agree with RollingRock, probably can make a big improvement just by cleaning. I've used the technique described with good success...others have also suggested for bad stains using some Johnsons Baby Wash to help out....just be patient and take your time....and definitely condition afterwards...also probably works a bit better if the ambient temperature is warm so the leather is as flexible as possible.
Old Jan 15, 2007 | 04:33 PM
jetmech23's Avatar
Thanks Rolling Rock and Plunds01 for all your help. I will try both of your suggestions.I will have to put off trying your suggestions till our weather warms up some.....the temp tomorrow is going to be 19 degrees in morning.
I think we are finally going to have some winter weather,it was 57 degrees here today.
