rear sway bar on 05 KR
over on the 04-06 group there was a discussion about rear sway bars. i had been thinking for a while that this could improve handling on my 05 KR. i ordered it and installed it this past monday. install was pretty easy. about an hour and a half. handling is GREATLY improved. the truck no longer dives into the turn. the rear end of the truck does not hop up in the air when it hits a bump like it did before. there are a few bumps that i try to avoid but end up hitting and without fail the rear end is up inthe air. so for comparison i hit them today and the impact is way different. this truck will never handle like a sports car but the difference is very noticeable. i have to say its the best $180.00 i have spent on a truck mod.
its an 05 4wd KR. got it from suspensionconnection.com. the SKU number they have for it is 7663 priced at 179.95
http://www.suspensionconnection.com/...scon/7663.html.
drove home in some pretty heavy rain last night and could only think of how stupid it was for ford not to put it on right from the factory.
i tried to copy and paste the picture from another thread but it did not work. do a search under the 04 - 06 group for "4x4 rear sway bar installation.... ". thats where i got the info. on about the 6th post down there is a picture that was scanned from the instructions. the bar u bolts to the axle. then there are 2 rods that ubolt to the round crosstube under the bed and connect to the swaybar. its that simple. i will try to get some pictures. but hope this helps in the mean while.
Here is the link:
https://www.f150online.com/forums/sh...r+installation
the stiffness and ride when truck is going straight on a smooth road is unaffected. very often when i would hit bumps the back end would jump up in the air and come down sometimes what felt like a foot to the left or right. i was speaking to a guy and he says that he experiences the same thing every day at the same spot. so for some unscientific experimenting i hit that bump before and after and the difference was dramatic. truck stays on the ground and just eats the bump up. i did not get this hop when i had weight, say 500 pounds in the back. so it is similar to that on the bumps without the sag and feel of a load.
on the turns the truck does not tip in or lean over into the turn like it used to. i am really surprised at the difference it made. the other night it was raining real hard and the truck seemed to grab the road on turns a lot tighter. i dont think you would be disapointed in getting this. besides its relatively cheap and easy to install. worst case take it off and give it to a friend.
hope this description helps
Originally Posted by centexKR
Looks like strictly for 4WD -- Do 2WD not exhibit this condition
Do the instructions say this can't be mounted on a 2WD F150?
This is a very cool mod and one I'll have to add to my "wish list". I have a very noticeable hop over speed bumps and it sounds like this would help. I'm going over to the 04-06 forum to get some more info... Thanks for the post!
heres a link for the same company for 2 wd. cant see why it wold not work the same. only difference i could see is how long the rods from the crossover tube to the rear of the sway bar are.
http://www.suspensionconnection.com/...on/7663F2.html
I'm trying to figure out the down side of these.
Ford puts them on the front end, so why not on the back?
Could it just be a money saving reason, or is there some other reason these don't come from the factory?
