King Ranch
slight wobble...
Old Aug 8, 2005 | 09:57 AM
TroyK's Avatar
slight wobble...
hey guys,
i've noticed that my truck has a slight steering wheel wobble around 65 to 70 mph. i saw that there is a tsb out on this. does anyone know what that tsb entails? is it just a good tire balance...? thanks...
troy
Old Aug 8, 2005 | 12:25 PM
Rockpick's Avatar
Moderator &
Troy...
Similar problem on mine at 72mph - 74mph. A simple balancing of the tires solved my problem for the most part.
I'm not exactly sure what the tsb calls for honestly...
Let me know what you figure out...
-RP-
Old Aug 8, 2005 | 01:32 PM
KRConvert's Avatar
As I noted in my last thread, I had the same issue. Doing a search on the 2004-2005 forum will yield that this is a problem for several other members also.
I took it back to the dealer, who balanced the front tires and then road-tested it. They declared it fixed but I still have a slight nibble at the same speed that you indicate. However, it is much better than it was before and I think I'll live with it for now.
When I take the KR in for it's 5000 mile checkup, they'll rotate the tires and we'll see what that does to the nibble. Another member said his went away after a tire rotation. Good luck to you and keep us posted.
Old Aug 8, 2005 | 03:16 PM
lrhogfan's Avatar
When I bought my Lariat, I test drove a black and tan like RP's and I wanted it bad, but it had a steering wheel vibration at about 65-70 mph. I drove it back to the dealer and told them that I wanted to drive the red and tan Lariat. I drove it and it was as smooth as can be. The salesman said that it was because of flat-spotting on the tires, but because of all of the problems about vibrations that I read about here, I decided to go with the red one.
I am very happy with my decision and very thankful to F150online.com for helping me avoid something that could have been a problem.
Old Aug 8, 2005 | 03:27 PM
TroyK's Avatar
wonder if the wobble has anything to do with the tires themselves? my truck has the optional wrangler ATS where as i think the standard tire is the RTS...right? i know i never had any problem with my '02 and its RTS tires...
Old Aug 8, 2005 | 03:31 PM
lrhogfan's Avatar
The standard tire is the BF Goodrich. I have the ATS and they are perfect. The black one that I test drove with the vibration also had the ATS. The brand of tires is not the cause of the wobble.
Old Aug 8, 2005 | 04:05 PM
TroyK's Avatar
well, i've had issues with brand new tires before...so i'll explore that option if it comes to that...hopefully a GOOD balance job will take care of it...
btw, does anyone here have full access to the TSB pertaining to steering wheel wobble??
Old Aug 8, 2005 | 07:43 PM
projetmech's Avatar
i think the common term for what you are describing is a nibble not a wobble. anyway, my 04 that i had did not have any nibble when i first got it. i rotated the tires and thats when it started. rather than going and getting them balanced i bought some new crossterrains since the stock were real bad in the rain and winter was near. with the crossterrains there was no more nibble and the ride improved dramatically. hope that helps.
Old Aug 9, 2005 | 07:33 AM
seacrow's Avatar
Mine has BFG Rugged Trail TA's and has the nibble also. I think this problem has more to do with having 18inch wheels than the brand of tire. I was told it's harder to balance 18's and up and keep them balanced.
Old Aug 9, 2005 | 08:19 AM
deltascrew's Avatar
refer your dealer to TSB 04-25-7 I goes over the steps to properly road force your tires.
Old Aug 9, 2005 | 11:51 AM
TroyK's Avatar
does anyone know if all dealerships can perform a road force balance?? i've never heard of this...
Old Aug 9, 2005 | 12:03 PM
Kool Aid's Avatar
Is this why the 06's are coming with 17's?
Old Aug 9, 2005 | 01:48 PM
deltascrew's Avatar
The dealer can perform this of they have a Hunter GSP9700/9712 Road Force balancer. My dealer bought one because of this problem with F150s
Old Aug 9, 2005 | 02:42 PM
deltascrew's Avatar
here's a link to the tsb
http://www.av8r.org/wpics/t42507.pdf
Old Aug 12, 2005 | 09:46 AM
TroyK's Avatar
thanks for the info guys! the only dealer around where i live that has that road force balancer is the honda dealership...! guess they'll be surprised when i show up with the KR since i am also "renting" an accord...
and then i'm sure my salesman there will say i shoulda got that titan...
