Introduction Forum Introduce yourself to the Community here! If you have a technical question, try posting it in the appropriate forum.
Hello
Old Dec 7, 2019 | 09:02 PM
yannis's Avatar
Hello
Hello everyone and thank you for accepting me to the forum.
I decided to join since there is so much valuable information available on the forum.
I own a 1997 F150 4.2L w/ 5 sp manual. It has a 1999 4.2L engine which just got antifreeze in the oil.
I am debating if I should fix or get another motor.
Old Dec 7, 2019 | 11:25 PM
Roadie's Avatar
Welcome! Depends on what is available I suppose. Good Luck with the repair or replacement.
Old Dec 8, 2019 | 03:29 PM
Since you caught it before it hydrolocked, I would do a full service gasket kit, and check tolerances.
Why scrap a good motor?
And Welcome!
Old Dec 8, 2019 | 11:20 PM
yannis's Avatar
And Welcome!
I think I will do that.
I will replace the lower intake manifold gaskets with the heavy-duty ones and replace the timing cover gasket as well which I think is the one leaking.
Do you know if they make a better quality than the standard one for the timing cover?
Thank you all.
yannis's Avatar
Thank you!
