Introduction Forum Introduce yourself to the Community here! If you have a technical question, try posting it in the appropriate forum.
Hello I Need Help
Old Mar 14, 2015 | 06:28 PM
purdue13's Avatar
Hello I Need Help
I've used this forum many many times while working on my 2008 F150 4x4 with 113,000 miles and this is one of the best f150 forums there are! so...now unto my problem this past weekend my battery light came on. I used my multimeter and my alternator was charging the battery roughly around 15.3 volts which I thought seemed high so I figured that my alternator was the culprit. I replaced the alternator and started the truck and ......o crap battery light still on. I used my multimeter to check the charge on the battery with the truck on and it was around 14.8-14.9. Also had autozone check with their instrument and they got the same readings. They said alternator was good and also battery checked out. No idea about the light. Took truck to oreilly's on their instrument they said battery was good but on last leg. Need help on what to do next....
Old Mar 14, 2015 | 07:28 PM
MitchF150's Avatar
If it's the original battery, it's 6-7 years old and that's about the life span of an automotive battery.
Mitch
Old Mar 14, 2015 | 07:52 PM
purdue13's Avatar
Mitch
Battery was put in in July 2012. Did spend two winters in Wisconsin. I do have a thread over in the 04-08 forum feel free to go over there and give your 2cents on this issue and see what others say. Thank you.
Old Mar 14, 2015 | 09:03 PM
MitchF150's Avatar
Well, you shouldn't post the same subject/question in multiple forums asking the same thing....
I'd look at the battery next, but that's just me...
Mitch
