Introduction Forum Introduce yourself to the Community here! If you have a technical question, try posting it in the appropriate forum.
Hello from the UK... And i need help
Old May 25, 2013 | 01:01 PM
badbob's Avatar
Hello There
My name is Bob Sanders and i live in Northamptonshire across the pond in England
I have a black 2001 Lightning which i have had for nearly four years it is my pride and joy i love it and it makes me smile every time i drive it i will post some pictures when ive worked out how to.
That was the introduction now for the technical help that i need
I recently detonated my engine snapped a rod and punched a big hole in the side of the engine block. I think this was down to a lean air fuel mixture which i am still investigating.
I have found another engine but it is from a non supercharged truck and after doing some reading i see that a few of you have bolted superchargers to your standard 5.4 engines so my question is how much boost can a standard 5.4 engine take? I was running a standard Lightning upper pulley and a #4 lower pulley is that safe on my replacement engine or should i just leave it as a standard Lightning setup?
Also does anyone Know the torque setting of the Flywheel bolts? As i have had to swap it with my original L flywheel as it has 6 torque converter bolt holes instead of Four
I hope this all makes sense
Thanks Bob
Old May 26, 2013 | 09:00 AM
badbob's Avatar
Well thanks guys that was a great welcome and some really helpful advice too
Old May 26, 2013 | 10:10 AM
The welcome committee was asleep! Great to have you. I see you have posted your questions in a thechnical forum, hopefully you will get some good input.
Old Jun 4, 2013 | 06:17 PM
