Introduction Forum Introduce yourself to the Community here! If you have a technical question, try posting it in the appropriate forum.
I'm a new guy with 12v 2001 F150 Screw
Old Apr 12, 2013 | 09:19 PM
That's freakin Bad A! I assumed the motor was some old v6 that somehow ended up in a screw haha. Gonna be throwing people off with the Cummins badges below the F150 ones haha
Old Apr 12, 2013 | 09:45 PM
Prochassis&fab's Avatar
Thanks SIX. It's a lot of fab work but it's cool cause I do it for a living... Lol.
Old Apr 12, 2013 | 09:48 PM
I put the truck on my scales before I took it all apart and it weighed 5640lb. Put it on them today and she weighed in at 6477 lb. not too much gain!!! I'm happy with it all and just gets better as I go.
Old Apr 12, 2013 | 09:50 PM
Thanks KMAC , the black smoke rolling will through em off too!!! Lmao
Old Apr 12, 2013 | 11:03 PM
str8t six's Avatar
what suspension setup did you use for the front?
did you just relocate the spring perches on the axle for the rear?
Old Apr 13, 2013 | 08:35 AM
SIX I used 2001 F250 n yes the 150 has a wider frame so relocated perches and moved the locate hole n the block forward 1". I used my 150 top spring and the rest are 250. Cause the 250 are 1/4" wider. Built the front crossmember and recessed a 2x4x1/4wall up into my frame and then boxed it all in to look clean.
Old Apr 13, 2013 | 08:44 AM
str8t six's Avatar
ok, thats kinda what i thought.
what year is the 12v? i know you said it was built, so how much power do you plan on making with it?
Old Apr 13, 2013 | 02:13 PM
Old Apr 13, 2013 | 02:14 PM
This is the bumper I made for it.
Old Apr 13, 2013 | 11:06 PM
Six I'm building the truck. The engine is only turned up to close to 300hp.
Turned pump up 2.5 turns in and 40hp fuel pin , turned fuel star 2 rounds and doing an intercooler that it didn't come with factory. Should be a tug machine!! Lol
Old Apr 13, 2013 | 11:21 PM
http://i1206.photobucket.com/albums/....jpg%5B/IMG%5D
Got my Radiator made to fit under core support. This will make room so
I can run the clutch fan instead of Ele fan. Less ele to worry about failing
Old Apr 13, 2013 | 11:25 PM
pizzaman711's Avatar
Dang this is a sweet build, and man that bumper looks awesome too! Keep the pics coming!
Old Apr 13, 2013 | 11:36 PM
Thanks pizzaman. Hope to get a lot done Tom at shop. That black truck of yours looks sick!! Love the red rings!!
Old Apr 13, 2013 | 11:53 PM
Veteran: Army
loving it, can't wait to see it tow
Old Apr 13, 2013 | 11:58 PM
Thanks man! They were originally silver when I got them, but I got bored one day and spray painted them red haha. But I've grown used to it again so I'm considering changing them to a different color sometime ha.
