LED wireing
Old May 24, 2002 | 11:01 PM
triton_4.6_power's Avatar
Unhappy LED wireing
Going to buy som LED's for my truck and install theme but I don't know how to wire theme, what size of resistor do you need, also were can you get the LED's, Radio shack? there supose to be 12V right, I don't know much about theme. Thanks guys!!
Old May 25, 2002 | 09:16 AM
XceLenT Driver's Avatar
T_4.6_P,
No problem.
Visit the link below:
http://www.bit-tech.net/article/68/
It will calculate those values for you and even speicify the color code and wattage rating of the resistor too!
The info it asks for is:
SUPPLY VOLTAGE- use 13.5V.
DIODE FORWARD VOLTAGE &
DIODE CURRENT (ma) will be found on the back of the LED package. (Most generic LED's are rated at 2.0V and 20ma resepectively.)
If you buy a "12 volt LED", it will have the resistor installed already.
Diodes are polarized so pay attention. The shorter of the two leads or the lead near the flat section of the diode's base is the cathode or negative side. The resistor can be attached to either lead on the diode.
No worry, If you bias it properly (a.k.a. use the proper resistor) and hook it up backwards, it won't "blow up", it just won't illuminate.
Good Luck... XLT_D
Old May 25, 2002 | 10:09 AM
hmustang's Avatar
You need to use OHM's Law to figure out you voltage and curret so you can find the right resistance to take the voltage away from the LED so you don't burn it up. Ohms Law is Curret is I=V/R Voltage V=IR and Resistance is R=V/I you can use any one of them or all 3 to figure what you will need for a resistor.
Old May 25, 2002 | 10:18 AM
Correct hmustang,
But that requires a little more electrical/electronic experience to apply. Simply repeating the formulas does not help him.
The "calculator" asks for some application specs. and then applies OHM's Law for you.
Triton... mentioned he has little experience.
With this tool he can fill in the fields, run it, and can take the information it (calculator) provides to Radio Shack, etc. for help in getting what he needs.
XLT_D
Old May 25, 2002 | 08:01 PM
hmustang's Avatar
No problem i was just putting out some info in case he wanted to use it.
Old May 25, 2002 | 11:49 PM
Thanks guys, I guess I got a project this weekend!!
Old May 26, 2002 | 01:06 PM
hmustang's Avatar
Have fun with your new mod and show us some pics when you get it done.
