shift knob
Old Jan 22, 2002 | 04:53 PM
masspimp's Avatar
Question shift ****
I'm new with my truck and I don't have a clue about anything yet. I was wondering if anyone could tell me if the shift **** on a 2000 f-150 x-cab is removable. It doen't seem to be but I don't know..
Old Jan 23, 2002 | 12:16 AM
LeanNCut's Avatar
Pimp,
I'm assuming that you're referring to a standard, right? If so then yes, you can remove it. But I do not recommend doing so. The dealer removed mine (who knows why?!) while doing an oil change and it was never the same. The **** would pop and come flying off the stick as I was shifting into 4th and roll around under the seat. I almost got into a wreck several times because of that. (I have tendency to "yank" it into 4th )
Anyhow, I notified the service manager but finally gave up on dealing with the BS and paid the $14 for a new one.
If you're still interested in removing the **** after all this then just turn it clockwise and counterclockwise several times. This will "grind" the plastic notches enough to allow you to pull it straight (up) out. But like I said, it may not stay on after doing this.
Hope this helps.
Old Jan 23, 2002 | 08:10 AM
SilverFlareSide's Avatar
or you could just pull real hard on it and keep the splines intact, and at the same time putting a dent in your roof...
Old Jan 23, 2002 | 02:18 PM
masspimp's Avatar
cool
Thanks fellas for the help, I wanted to know so I could slap one of those fancy shift ***** on there. I'll try not to put a dent in the roof lol.
