where can i get diff. colored bulbes for acc. lights
Old Dec 7, 2001 | 03:59 PM
crazedf1's Avatar
i would like to know because i would like to make them red instead of green. the ones i want to do are the ones behind the ac swithces and maybe the instrument cluster. does anyone know of the bulb to use and if there are any other colors perfrably red.
thanks
Old Dec 10, 2001 | 04:07 PM
my97offroad's Avatar
dont know what size they are, but I bought red bulbs for the lights on my door panel at Kragen. They also sell little rubber covers to go over the bulb. Not sure if the bulb behind the dash is green or if the actual lense in the instrument cluster is green. I think it may be the cluster.
Old Dec 10, 2001 | 05:17 PM
crazedf1's Avatar
i took it apart today, and the bulb is a clear bulb w/little color in the inside(dont know what it is for) well anyways i think it is the cluster that has a green film ot something on the inside(did not take it all apart) so does anyone know what the prob. is or should a say a solution?
Old Dec 14, 2001 | 12:37 PM
Jimmy Lee's Avatar
My bulbs all blew and i just colored the clear bulbs with a red permanent marker.this works fine!!
JJ
Old Dec 20, 2001 | 09:11 AM
crazedf1's Avatar
does the faces illuminate red or that green color?
Old Dec 20, 2001 | 11:08 AM
sundog7's Avatar
You can find red and blue at AutoZone. I bought Blue for the overhead light. Didn't seem to make much difference.........Needs to be "bluer" to make a real difference.
Old Dec 21, 2001 | 07:37 PM
KYFordFreak's Avatar
Sundog7
Are you tlaking the dome light or the overhead map lights. I have the map lights but couldn't find the right size bulb for the dome. It's not a 211, although with a little tweaking it might fit.
To make mine show more blue, I lined the plastic lens's with a blue sheet of plastic, big difference. Just went to Wal-mart bought a blue plastic folder, traced shape and cut it out, then used double sided clear tape (industrail strength).
Old Dec 24, 2001 | 11:29 AM
sundog7's Avatar
I forget the number, but it's the bullet-shaped light for the dome. I'm also going to go with colored mylar sheets. A colored bulb just isn't cutting it.
