2009 F150 door panel removal to replace mirror
2009 F150 Lariat. Wife had width problem with garage door and cracked the mirror housing to the point I have to replace it. Can anyone help with the inside door panel removal?
Thanks |
This thread is for changing the speakers but should help with getting the door panel off.
Post #5 https://www.f150online.com/forums/sp...gular-cab.html |
Thanks, after reading the post I ordered the mirror and will post when I "git 'er done".
Almost "got 'er dun"
Well I followed your excellent directions to a T. Only problem is that the nut or whatever on the inside of the metal door liner disappeared when I took out the bolt behind the door handle. Now I have a hole but no means of attaching the bolt thru the plastic door handle trim and anchoring it in the metal door liner.
Am I screwed? I have to believe there is some sort of fastener that I can either use like a wall anchor (0 depth) or some other anchor for which I have no name. Can anyone help? Mirror looks great but inside of door looks a little cheesy with the door handle hanging loose.:) Gary |
