Window Trouble
Old Dec 19, 2012 | 07:08 PM
Trav1500's Avatar
Window Trouble
My gf has a 97 single cab f150 xl, the passenger window hasnt worked for about a year and her father replaced the regulator about 6 months ago with no luck. I checked all the fuses, wires seem to be fine, but there is no movement up or down when the button is pressed from the drivers side or the passengers side. There is no sounds from either the window motor or the engine bay(read in another forum about a clicking noise from the bay?). The drivers side window works fine. Are there any fuses i may be missing? i checked only the ones under the dash. Or is there another component i havent considered, thanks
Travis
Old Dec 20, 2012 | 12:10 AM
jgger's Avatar
Look in the DIY's, there is a writeup to fix a defective window switch.
If that isn't it then it could be in the wires where they go from the door to the cab. They can wear out/break there from door movement.
Old Jan 3, 2013 | 09:57 AM
Trav1500's Avatar
Alright, thanks for the feedback. Im hoping its just the door switch.
