O/D Button Stuck on 2007 Lariat
Old Jul 2, 2011 | 07:15 AM
Sport150-4x4's Avatar
I got a little help from my wife who spilled some special coffee on the console that has made the O/D button stick down when pressed. It eventually goes up on a hot day, but it will not reset off/on. There's no clearance to try to wipe around it and I'm not thinking I want to put a lot of water on it to try and rinse it out.
I was wondering if anyone knows the trick to take the console apart around the shift lever.
Old Jul 3, 2011 | 09:44 AM
fatty4x4's Avatar
Take a look at this link.
https://www.f150online.com/forums/20...tructions.html
Scroll down to picture 10 through 12. On picture 12 you will see the plastic tabs holding the silver cover on. Carefully pull those tabs back to release cover exposing the O/D switch. Good Luck!
Old Jul 3, 2011 | 10:18 AM
XL1200Ltd-Keith's Avatar
I used WD-40 and TriFlow to loosen mine up after a coffee spill, it took quite a few cleanings to completely free it up. If it happens again I will try the CRC QD Electrical Cleaner to flush it out.
I could not find the O/D switch, or the chrome bezel for sale, I believe that they are part of the complete shifter assembly.
