Seat tilt
Old Jun 7, 2010 | 12:07 AM
znhunter's Avatar
Seat tilt
I have sat in my passengar seat a couple of times and its really not comfy is there anyway i can tilt the seat up and down by turning some nuts and bolts.I dont have and power controls on the seat i have a 2003 supercab
Old Jun 7, 2010 | 01:08 AM
thejake1989's Avatar
Tilt the back?? The passenger seat will move just like the driver seat will
Old Jun 7, 2010 | 08:52 AM
znhunter's Avatar
yea yea i was talking about the bottom of the seat
Old Jun 7, 2010 | 09:24 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
The Lariat trim had a power drivers seat.
The passenger seat is what it is, from 97-03 regardless of trim lines.
The only way to adjust the seat bottom on the passenger side is to go aftermarket.
Old Jun 7, 2010 | 08:43 PM
znhunter's Avatar
i have a xlt fx4 f150 and it has a power seat but if i could find another power seat on the drivers side of another f150 and i just moved the switch to the opposite side could i work it in my passengar side?
Old Jun 9, 2010 | 06:59 AM
mjb1032's Avatar
Znhunter,
I have an 04 (new style), and the seat bottoms were way to flat for me.
Here's what to do (it worked perfectly),
Remove a seat and flip it over onto a sawhorse or bench.
You will find that there are four bolts holding the lower cushion to the seat frame.
Loosen the rear two bolts, but don't remove them.
Remove the front two bolts and buy longer ones, the length can vary with how high you want to lift the seat angle.
Add washers/spacers to lift the front of the cushion (between the cushion and frame).
I did this years ago and love it, (I also tilted the pass seat to match).
The truck is much more comfortable to drive having support under the front of your upper legs.
Good Luck, and let me know how you made out.
Marc
