Pic! help!! About to go insane!
Old May 21, 2009 | 01:30 AM
cmolina07's Avatar
Angry Pic! help!! About to go insane!
Has anyone had a clicking noise happen in the circled area??? i have no found a single answer on the forums help would be GREATLy appreciated
Old May 21, 2009 | 09:57 PM
gcw's Avatar
gcw
i have a rattle on the other side same spot its very annoying
Old May 25, 2009 | 12:11 AM
Peladho's Avatar
Had a squeaking
No rattle from there but my plastic wont seat right even the dealer cant make it seat right.
But what I had earlier was a squeaking from there and that turned out to be a loose wire bundle that was rubbing when hot and only when top Dealer took care of that under warranty
Old May 25, 2009 | 12:29 AM
Are you positive that it doesn't come from the electrical module mounted on the kick panel just below that?
Old May 25, 2009 | 12:31 AM
One other thought. I get a popping noise from right around there when there is a big temp change. If it's cold andI turn the heat/defroster on.
Old May 25, 2009 | 01:12 AM
FLYAF's Avatar
Is your EATC module working fine ? I had that clicking noise when it was on the fritz and as Bluejay mentioned its an electronic relay thats making the noise. I was able to fix it by just unhooking the EATC module thus resetting it and hooking it back up.
Old Jun 7, 2009 | 04:25 AM
cmolina07's Avatar
where can you find it again sir??
Old Jun 8, 2009 | 02:05 AM
ATOM1's Avatar
is the window trim snapped down? i know that mine is kinda touch and don't snap down very well, but it's not really a clicking sound
Old Jun 11, 2009 | 02:26 AM
cmolina07's Avatar
yeah for some reason it dont wanna stay in
Old Nov 27, 2009 | 02:59 PM
djcipria's Avatar
It's likely the blend door for the a/c unit. Mine has climate control but I have heard that it can be an issue with standard a/c controls as well.
Old Nov 27, 2009 | 03:15 PM
Mine makes that noise up there after I installed a cowl hood. I think air pressure outside the cab influences the noise, as stupid as that sounds. :o Maybe it's coming from under the cowling or the wiper.
Turning up the radio makes the sound does make the sound disappear though.
